Browse Forums General Discussion 1 Nov 19, 2009 5:35 pm Does anyone know if you need heat cans on halogen downlights if they are on the lower storey of a two storey house with no insulation surrounding them? Re: Downlight Heat Cans 2Nov 19, 2009 6:24 pm Hey there Do you mean low-voltage halogens (I presume you do) cos I think the protective device thingys are mandatory now and you have to buy the whole kit. The LED downlights are much cooler but we've already tested some and frankly the light is not the same..it's a much weaker light imho and nowhere near as 'warm' in tone. (DH, if you are reading this, I'm gearing up for a battle on this...LOL) Pix Built a (highly) modified Allcastle Maxworth 38.7 in Sydney. Re: Downlight Heat Cans 3Nov 19, 2009 6:45 pm Hey Pix Yeah I meant the low voltage Halogen 12V variety. My understanding is that it's mandatory if they are near insulation but I'm not sure if you need the cans if they aren't. Thanks Re: Downlight Heat Cans 4Nov 19, 2009 10:27 pm What's a good brand or should I say where is good to get them? we want to get some of these for ours. Re: Downlight Heat Cans 5Nov 20, 2009 1:01 am I found these, they have a place for the transformer as well which I can't find on others yet. http://www.specifier.com.au/articles/30 ... l?cid=2343 Re: Downlight Heat Cans 6Nov 20, 2009 1:02 am They are from here http://www.arrowform.com.au/index.asp and the pdf link http://www.arrowform.com.au/images/AF%2 ... ochure.pdf Re: Downlight Heat Cans 7Nov 20, 2009 1:17 am If you have a squiz in your roof space, you will see there isn't just insulation. there is dust and debris that blows in. So that will lay on the transformer or downlight and in most cases be more flammable than insulation. I'd be using them regardless of insulation being present or not. There may be answers here but can't find anything. I have a closed in veranda, four windows. North facing, just had sunblock blinds installed. A bit cooler (actually… 0 2977 |
