Browse Forums General Discussion 1 Nov 11, 2009 7:14 pm Hello Forum, Still searching for an alternative wall system to brick and came across another post which mentioned the FormaTech system. Just wanted to know if anyone has used it or know of some who has? I need the a Miracle wall - thin as possible, great accoustics and fire rate to suit a boundary. Any feed back would be great. Re: Anyone used Formatech / Forma Tech system???? 2Nov 16, 2009 4:24 pm Hi details at www.formatech.com.au As title suggests, looking at using the interlocking Pentablock stacked stone products to replace failing timber retaining… 0 17864 there is only 20% difference in concrete strength between 20 mpa and 25 mpa, so check with your engineer first if it fits his calculation tolerances. There are ways to… 6 18298 Once you know the basics, the rest is easy. Read my post in the thread linked below. viewtopic.php?p=1919271#p1919271 2 19515 |
