Browse Forums General Discussion 1 Nov 05, 2009 3:31 pm has anyone had any experience with heat pump hot water systems. There seems to be a lot of negatives written about them and I have heard they do not work well in colder climates. We are in Victoria. Would you go heat pump or solar for your hot water? gas is not available so it solar will need an electric booster. Re: Heat Pump hot water system ? yes or no ? 2Nov 05, 2009 3:39 pm We have had a Rheem 315l heat pump for about 5 months now. No major issues with the noise...about the same noise level as an air conditioner condensor motor (as you would expect). Re: Heat Pump hot water system ? yes or no ? 4Nov 09, 2009 3:46 pm We've got the newer model Rheem - MPI325 (325L) I think its called which was the quietest on the Aussie market when we got it put in (AUG 09). No issues at all, water is always nice and hot, copes fine with four loooong showers in day along with washing up in the sink during the day and dishwasher load on semi-intensive at night (although don't dishwashers heat their own water?). Located in Brisbane's suburbs and it tends to work the most in the morning 6am - 9am. Al & Caitie- Building the Hamilton 278 (Coral) at Narangba Re: Heat Pump hot water system ? yes or no ? 5Nov 13, 2009 8:22 am yer our heat pump is fine, quiet'ish a/c unit noise, we have it outside the kids activity room and its not noisy enough to bother closing the window next to it, you can barely hear it Blog - http://snakedr.blogspot.com/ Build Thread - viewtopic.php?f=31&t=12084&p=307406#p307406 Status - PCI 15/10. Things nearly done. Re: Heat Pump hot water system ? yes or no ? 6Nov 15, 2009 6:43 am Dux Airoheat now cater for sub-zero areas, so it should be fine for your area. Possumchops Now the proud owner of 3.7acres of Serenity. Colour selection completed! Soon to go to council. Re: Heat Pump hot water system ? yes or no ? 8Mar 01, 2010 8:07 pm Possumchops Dux Airoheat now cater for sub-zero areas, so it should be fine for your area. Am I the only one that found this funny? Renovation Thread: viewtopic.php?f=31&t=38489 Re: Heat Pump hot water system ? yes or no ? 10Mar 03, 2010 4:52 pm In victoria, without <0 temps we run both Rheen and Quantun heat pump hot water units on commercial applications and I would steer clear of the rheem units that require large elements, Check to see what rating of electrical power is required. I would recommenr Quantum units. They have operated well and other suppliers rebadge them and sell them on. The operate on lower external temperatures and the company has the internal staff who actually know their products. Ring and discuss it with them. Heat recovery units will always have slower recovery times (time taken to reheat the water) than other types. Personally I am going with evacuated tubes with natural gas continuous flow back up. EV tubes work well. Re: Heat Pump hot water system ? yes or no ? 11Mar 05, 2010 9:50 am alk We've got the newer model Rheem - MPI325 (325L) I think its called which was the quietest on the Aussie market when we got it put in (AUG 09). No issues at all, water is always nice and hot, copes fine with four loooong showers in day along with washing up in the sink during the day and dishwasher load on semi-intensive at night (although don't dishwashers heat their own water?). Located in Brisbane's suburbs and it tends to work the most in the morning 6am - 9am. How much was it? the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14059 Thanks good to know. How big is your tank? So you can set when your heat pump runs? How do you do that? How's the speed to heat? Is there such thing as instantaneous… 4 929 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20232 |
