Browse Forums General Discussion 1 Oct 27, 2009 7:11 pm Some people don't have time to do the job right the first time, but seem to have plenty of time to fix their mistakes. Build Thread Re: Conversions from Lot Numbers to Street Numbers - HELP!! 3Oct 28, 2009 11:27 am Some people don't have time to do the job right the first time, but seem to have plenty of time to fix their mistakes. Build Thread Re: Conversions from Lot Numbers to Street Numbers - HELP!! 4Oct 28, 2009 12:12 pm Metricon Riva 33 - http://herlihy-riva.blogspot.com Site start 15/03/2010 - Handover 23/12/2010 9 months and 8 days (284 calendar days) from site start to handover Re: Conversions from Lot Numbers to Street Numbers - HELP!! 5Oct 28, 2009 1:48 pm As a side note, the aerial photography in the link above is more current than google earth. It was flown Jan 2009, although the resolution and navigation is not as good as GE. Re: Conversions from Lot Numbers to Street Numbers - HELP!! 6Oct 28, 2009 3:38 pm ifyareckon As a side note, the aerial photography in the link above is more current than google earth. It was flown Jan 2009, although the resolution and navigation is not as good as GE. I've had a look but can't find the aerial photography part. Our estate is still bushland on google earth so I'd love to see if this is better. Thanks! Re: Conversions from Lot Numbers to Street Numbers - HELP!! 7Oct 28, 2009 6:47 pm That's awesome. I have tried it before but now we're getting closer to title it seems to be there now. If things dont change we will be living in house 14 (the same as my parents place, which is we're I am still living) I like it Re: Conversions from Lot Numbers to Street Numbers - HELP!! 8Oct 28, 2009 9:37 pm dilla ifyareckon As a side note, the aerial photography in the link above is more current than google earth. It was flown Jan 2009, although the resolution and navigation is not as good as GE. I've had a look but can't find the aerial photography part. Our estate is still bushland on google earth so I'd love to see if this is better. Thanks! Once you have found the adress, go to the build map section. Click on the folder marked aerial photography and check the box under it mared aerial photography 2009 or something to that effect. Hit the refresh map and you are set. You may also need to uncheck the box with zoning information, this can sometimes sit over the aerial. Re: Conversions from Lot Numbers to Street Numbers - HELP!! 9Oct 28, 2009 11:31 pm ifyareckon You may also need to uncheck the box with zoning information, this can sometimes sit over the aerial. Or slide the "Adjust Map Transparency" slider to the left so the top layer becomes transparent. Thanks for the 'heads up' on this one, ifyareckon. Pfiff Finally making progress again, with a clothesline (yippee) and some much needed little things being attended to over the holidays. 40 C on New Year's eve? We love our a/c! Re: Conversions from Lot Numbers to Street Numbers - HELP!! 10Oct 29, 2009 3:35 pm Oh, I see why I could't find it. It's only for Melbourne areas, not for those of us out of the city. Hi all. I'm thinking of installing an electric gate in front of this street front villa (link below). The gate would be between the bush on the left and the letter box on… 0 2790 Thanks! I'm spoke to the builder I'm not sure if this is all true but basically went along the lines of they considered all options and if I was to compact and fill it… 2 7319 Would anyone on this forum know of a builder/company in Brisbane with house designs for a shallow block. I have a block 20 x 20 so with front and rear set backs I need a… 0 4759 |
