Browse Forums General Discussion 1 Oct 10, 2009 11:08 pm Hi everyone, I am new and long winded so be kind please. I want to line our lounge/TV room with plaster board and I am on a limited budget. I am confident I can do the job myself however I need some tips on the correct method of fastening the plaster to the various surfaces in this room. Two opposite walls are cavity brick and the other two opposite walls are tongue and groove cyprus pine, secret nailed to stud walls. (the bricks are very dark and the timber has aged quite dark also and we want to brighten up the place and eliminate the dust that collects on the rough brick walls). The gable ceiling (also tongue and groove cyprus) is of the cathedral style, with exposed 125mm rafters resting on 250mm laminated beams. There is virtually no ceiling space and the the room is very warm in summer. I would like to fill between the rafters with pink bats and fit a plaster board ceiling under the rafters to retain the insulation. Q1. What preparation, adhesive and method should be used to attach plaster board to the brick walls? Q2. Ditto the timber walls? Q3. Ditto the ceiling. Should I use battens? Thanks in advance, Bob. Hi, I am sheeting the inside of a 5.7 x 8m shed with gyprock. Unfortunately the shed wasn't designed for internal cladding but I have been framing it up as strongly as… 0 3416 Hi, I'm new to this forum so I hope I'm doing this post correctly. Please advise if it's not. I've just bought my place. The inground pool has a marble lining that has… 0 13663 There are a lot of private inspectors should have stayed working as tradies!! Firstly, you paid for a professional opinion of the works, if he has picked up on an item he… 1 2022 |
