Browse Forums General Discussion 1 Oct 10, 2009 9:13 pm our new house got completed in Jan this year (so it's 9months old) we are having problems with some of the downlights. I've tried replacing the globes but they still don;t work. How long do the transformers normally last for downlights and should the builder replace them? Do they have a certain warranty period. it's in the bathroom and laundry which means these lights aren't even used that often. i think each light has a separate transformer. thanks for your help Re: down lights - transformers, how long do they last? 2Oct 11, 2009 9:02 am We had a similar problem when we moved into our house about 8 years ago. Back then we didn't even think of contacting the builder. Our electrician just replaced the faulty transformers and we paid for them. It turns out that there was a poor batch of transformers and these failed quite easily. We have since replaced most of them and have had not problems since, now we only replace the globes and this is only rarely. View our blog at: http://room4acubby.blogspot.com/ Re: down lights - transformers, how long do they last? 3Oct 11, 2009 12:40 pm Down lights as a complete unit with transformer costs only about $9-12 so ur better off buying a couple as spare and just get them replaced as trying to chase up ur builder for the cost i wouldnt bother ... Re: down lights - transformers, how long do they last? 4Oct 11, 2009 1:23 pm Transformers should last pretty well forever. If you have a problem it's either a manufacturing defect (covered by mandatory 1 year warranty) or a loose connection (try disconnecting and reconnecting any connections on the low voltage side). Demolition August 2009, Construction Started September 2009, Completed December 2010 Ask the council if there is a chance of getting build over easement exemption. Sometimes easements are unused and 24cm is not all that much. Good luck. And yes any builder… 2 13781 So I'm just reading up on this ecosystem of lights. I'm planning on putting deck lights along the outside edge of a large deck. Will need about 3 packs (18 lights) plus… 0 23025 |
