Browse Forums General Discussion Re: tenant not paying rent 3Oct 07, 2009 7:09 am 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: tenant not paying rent 6Oct 09, 2009 8:42 am Blog: http://bluemistkids.blogspot.com "Never be afraid to try something new. Remember, amateurs built the ark, and professionals built the Titanic." Re: tenant not paying rent 8Oct 09, 2009 12:55 pm viewtopic.php?f=31&t=22766 - my build thread! Time waits for no man. Unless that man is Chuck Norris. Re: tenant not paying rent 10Aug 23, 2012 11:06 am Go read the relevant legislation for Victoria - it will be called the residential tenancies act or something like that. Unlike alot of other legislation the tenancies legislation (at least the ones I've looked at) seems to be drafted quite well and relatively straightforward. It will describe the circumstances in which you can give a notice to vacate, and what the proper processes are to make it stick. The terms should be reflected almost identically in your tenancy agreement with them. For example, for our tenants in the ACT there is a process of issuing remedy notices for late payment of rent. After a certain number of notices have been issued and a certain amount of time has passed you issue a notice to vacate and seek an order for termination from the tribunal. You need to follow the proper process or you won't get the order. A notice to vacate for on no particular grounds is also a sensible approach, if you can afford to miss the rent for that long. Tender /1/12 Contract 14/6/12 Planning 12/10/12 Site 23/10/12 Piers 27/11/12 Slab 12/12/12 Frame 15/12/12 Trusses 17/1/13 Roof 24/1/13 Bricks 13/2/13 Plaster 1/3/13 The gap can be adjusted so it's tighter. You can definitely set up corner cabinets to have the same gap as standard doors. 2 13457 The HIA contract, in the term & conditions section states that "Commencment" is deemed when the drainage is started or the piers are dug or the slab is formed up (incase… 2 6109 DIY, Home Maintenance & Repair But if it is a ground level open pit, then it is not a charged system. No surprises there. The pipes have obviously been altered and there would be a reason for this.… 3 31235 |
