Browse Forums General Discussion 1 Jun 24, 2007 1:11 pm Moderators, please be patient with this post. I know it should have gone into the doors section but hopefully I'll get more response in here. Would anyone in Melbourne know of a good door supplier. I'm in the middle of a hallway reno and need to replace my front entrance door. It was originally a Jennings built house and has a non standard sized door. I have found a great security door supplier and now I'm looking for a door supplier that will measure and fit a new front door. Any recommendations would be appreciated. If all you can see are obstacles, you have lost sight of the goals Re: Entry Doors 2Jun 24, 2007 3:28 pm Perhaps try Doors Plus
http://www.doorsplus.com.au/ They seem to have a good range and you can see it online.. or Canterbury Doors http://www.canterburywindows.com.au/# Re: Entry Doors 3Jun 24, 2007 11:04 pm Neil
How much different is it from standard sizes? Maybe you could go for a stock door from one of the suppliers Matt mentioned and have someone trim it to size and intall. I am assuming that you would want a solid door being the entry, but you can get away with trimming a little from hollow-core doors. Good luck Tony Re: Entry Doors 4Jun 25, 2007 6:57 am uncle_ant Neil How much different is it from standard sizes? Maybe you could go for a stock door from one of the suppliers Matt mentioned and have someone trim it to size and intall. I am assuming that you would want a solid door being the entry, but you can get away with trimming a little from hollow-core doors. Good luck Tony Thanks Uncle. This door is WAY bigger than a standard sized door. Jennings had a bad habit of fitting oversized doors, not sure if they still do. It would be great if it was a small door and then I could easily trim it myself. I had thought of making the aperture smaller, but the time needed to do that would mean I'd be without a door for more than a day; not a thought I'd cherish. If all you can see are obstacles, you have lost sight of the goals Re: Entry Doors 5Jun 25, 2007 8:43 am What size door is it ? Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: Entry Doors 6Jun 26, 2007 7:37 am ausdesign What size door is it ? It's 870 x 2160. As of yesterday afternoon, it looks like I found a local joiner to make one for me. I'm just waiting for him to get back to me today with a price. If all you can see are obstacles, you have lost sight of the goals Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6357 I am looking to design an entry door to a lower ground basement that has 2200mm between the external entry height to FFL of the ground floor. This door will provide an… 0 11383 we have a standard size and often we have a lot of variety to choose 0 3579 |
