Browse Forums General Discussion 1 Jun 22, 2007 5:15 pm I am currently considering replacing my aging gas hot water service with a Flat Panel Solar Hot Water system. I have heard good things about them but when doing some research on the net came across some concerning developments about solar panels in New Zealand. NZ is different but Australian coast areas are similar.
My concern is that I don’t want to install a unit and have it rust out in 12 – 18 months. The payback period is supposed to be 7-10 years. Hence my concern. The websites I have been looking at are as follows: http://www.rustypanels.info/ http://www.consumer.org.nz/newsitem.asp ... ng%20alert I realize a problem in NZ does not mean that there will be one in Australia. The articles do suggest that once the panels are installed that they are out of sight and out of mind. If you don’t carefully examine your gas bills you would not be aware that the system is rusted out and that the gas booster is working ALL THE TIME. If I want a gas booster I will just buy one. So do solar panels work? AND do they keep working? Al Re: Solar Flat Panels - Great? or Gross? 2Jun 22, 2007 6:07 pm I think you'd have to say a definiate yes to solar hot water being cost effective
The info below I received from the ATA should help with your decision. It was a presentation they did and they talk about rust in here. What you should do 2 If you're retrofitting an existing home - fit low flow shower heads or flow restrictors, lag accessible hot water pipes. You can engage a water or energy auditor - some plumbers do this - to check your system and advise how it can be made more water or energy efficient. When they're due for replacement, select water and energy efficient appliances. What you should know 1 Solar water heaters come in various styles but all have some sort of panel - referred to as a solar thermal collector - or collector panel or just collector. In a close coupled thermosiphon system the storage tank is coupled directly to the top end of the collector panel. Heat from the panel rises and heats the water in the tank. A gas or electric booster is fitted to heat the water to required temperature if the sun's heat was insufficient to do this during the day. This can be in the tank or after the tank What you should know 2 Alternatively thermosiphon systems can have the tank under the roof, collector piped to tank, same boosting as close coupled system. Might be considered more aesthetically appealing especially but need space in roof cavity that is higher than panels. What you should know 3 Split system has panels on roof and tank on ground. This requires an electrically powered pump. Blackout will stop pump. Need room for tank close to house. Not always possible to locate it close to bathroom or kitchen where hot water needed, What you should know 4 Other system types Evacuated tube collectors - high efficiency, less prone to shading. Better in low light but more expensive than flat plate. Plastic construction - tank & collector - won't split due to expansion when frozen Gravity feed - solar systems can be designed for low pressure systems - ask plumber about this. Combustion heater boosted - also possible but speak with plumber. Might hear of heat pump - not a solar collector but high efficiency electrically powered heater that operates like air conditioner: extracts heat energy from outside air or from earth using buried pipes and transfers to water. Can be used alone or as booster in solar system. What you should know 5 Tank material Stainless steel and plastic tanks - no corrosion protection required Glass lined steel - sacrificial anode - aluminium or magnesium rod in tank to prevent corrosion of mild steel - needs replacing occasionally What you should know 6 Heating method Direct or 'open' system - water flows through collector and into tank Indirect or 'closed' system - heat transfer fluid flows through collector. Heat exchanger in tank transfers heat to water. Needs topping up occasionally. Combats freezing and corrosion What you should know 7 Boosting methods Electric element in tank - requires J tariff meter and time switch or other control. Gas heating in tank - needs electricity to ignite flame. Both systems are thermostatically controlled so don't operate if water already above required temperature. Care needed with electric boost - turned on by timer or ripple signal via 240 V power supply - both controlled by electrical supply company. Might find heater comes on when plenty of sun but supplier wants to dump surplus electricity at a time of low demand. Gas heating on outlet 'instantaneous'. Temperature controlled - comes on only if required. More powerful heater than tank mounted type - may need high gas flow available to house. Mains gas supply can affect choice of method What you should know 8 Terminology: Thermo siphon - hot water rises to tank, cold falls and circulates naturally without an electric pump Tempering valve - adds cold water to hot outlet to prevent scalding Pressure-temperature relief valve - opens at set pressure to drain water. Protects system against over pressure or boiling. Can cause water losses in summer What you should check 1 Interesting to know how much electricity or gas you're using to heat water. Estimating electrical water heating (J tariff) units Check your quarterly electricity bill for the units (kilowatt hours) consumed. Divide these by the number of days covered by the bill OR Read J tariff meter at start and end of typical week then divide by 7 = kilowatt-hours per day What you should check 2 Estimating gas water heater consumption Check your Summer quarter gas bill for the total megajoules or cubic metres - although may also include cooking and other gas appliances Divide these by the number of days covered by the bill OR Read gas meter at start and end of typical week then divide by 7 = cubic metres per day What you should check 3 Estimating hot water usage - system supplier will ask for rough estimate - this is more elaborate method than they will need but it's interesting to know: Bathing habits - how many baths per day? Measure bath water - (L x W x water depth in cm) divide by 1000 for litres How long total shower time per day? Check shower flow using bucket and timer How many batches of washing per week and what proportion is hot water? Washing machine capacity - see user manual What you should check 4 Collector position Do you have a section of North facing roof for collector (check Sun at noon) Is roof angle 40 to 50 degrees (or frame mount) Unshaded during most of day - is it clear of trees. Check over the day as the sun moves across. Where is hot water needed? If there's a choice of locations for the collector, pick one that minimises length of hot water pipe runs to taps and the amount of dead water - cold water that needs to be runoff before hot arrives at tap. What you should check 5 To select the best system for your needs and situation consider: Tank on roof - aesthetics and roof strength Tank on ground - available space, how close to taps, power needed for pump Gas pipe size for booster - measure OD of tube What is water quality? Is it from mains or bore - analysis by water quality kit or ask water supplier Is there risk of frost? Can determine whether need a direct system (water flows through collector) or indirect (heat transfer fluid used) What you should ask 1 From hot water system supplier Warranty on panel. Warranty on other parts What happens if there's a power blackout? Circulating pump will stop, gas burner may not ignite How does booster control work? When does it turn on? How does it ensure all available solar energy is used before using gas or electricity? How does temperature limiting work and does this cause water losses? What maintenance is required? What you should ask 2 From hot water system supplier or others Government rebates - how much and what conditions? How does mains gas availability affect choice of boost type? Ask for explanation of renewable energy certificates or RECs. Government issued certificates to encourage purchasing of renewable energy generating systems. RECs act as a green energy trading system, they have a monetary value and can be sold to businesses who must meet renewable energy targets. Their value might have been already deducted from the price so the retailer does not give you the RECs. Ask this. What you might ask Payback period - often asked about concerning renewable energy. Nobody asks the payback period on a new car or a home improvement such as landscaping - or even a university degree. There are many variables - the system cost, how much sun you receive and how much water you use. Solar hot water systems are environmentally friendly, sun is free, surely it is just common sense. I see plenty of solar collectors in gloomy old England. And these links should help U too. http://www.greenhouse.gov.au/yourhome/technical/fs43.htm Check at the new vacuum tubed solar systems from solarhart too. http://www.greenhouse.gov.au/renewable/recp/solar/pubs/solar5.pdf Cheers Steve Solar hot water units 3Jun 26, 2007 1:47 pm I would consider evacuated tube solar hot water.
From the research I have done they are up to 40% more effective than flat panels there are 3 or 4 models available. Check these out: http://www.endless-solar.com/ http://www.sunpluscpc.com.au/ Go well! I'll show you how to keep your new home betwen 15 and 26 degrees celcius all year round - in your buget - GUARANTEED! www.sunrisehomes.net.au CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16560 Hello - we were hoping to apply laminate click lock panels to our concrete ceiling, but not too sure how to go about attaching the panels to the concrete. Any idea what… 0 1680 0 10939 |
