Browse Forums General Discussion 1 Sep 23, 2009 8:05 am I had painstakingly chosen all appliances and the fridge I chose was a double door Westinghouse. Typical of me, I don't measure anything & just liked the look of it, so last night we decided to get the measurements of both freezer & fridge & both appear really small compared to my current fridge There are only two of us at home but I still want a decent size fridge I dont think this is near enough for my use. Anyone who has a double door, are you happy with the size & amount you can fit in Jazz Life is like a lolly, suck it and see Re: Double door fridge - is it roomy enough? 2Sep 23, 2009 8:23 am myself and my gf are only using a bar fridge at the moment as we will get a nice new fridge after rennovating next year i presume. when choosing this fridge - did you actually open the doors and inspect? or did you make your choice online based on looks and cost.... if so sounds like you need to go into a harvey norma/dj's etc and try using them all. Re: Double door fridge - is it roomy enough? 3Sep 23, 2009 9:56 am We got a Westinghouse double door fridge/freeze (with water/icemaker) a few months back as a replacement for our old Fisher & Paykel which was damaged - I can't remember the exact model number, but it is no where the size of our standard top/bottom one - we do manage (family of 4), but can be quite tight the couple of days after grocery shopping. We have a second freezer too, as the spaces in the freezer really are minimal, esp with the space the icemaker takes up at the top - also the other thing to be careful of is that it is frost free - stupid me assumed all modern freezers would be frost free - but this one is not and we already have a build up of frost, which is not going to be fun to clean - . Like you I picked this fridge mostly on looks (and I was rushed to decide as it was an insurance claim) - it does look good, but is that enough to sacrifice the internal space...? Hope this helps - good luck!! Building on the Sunshine Coast - Land settled 22nd July 2009 Building contract finally signed (after much deliberation on our part) 11th November 2009 Building commences 25th January 2010 - small local builder End of June - almost completed fit out 26th July - MOVE IN DAY!!!!!!!!!!!!!! Re: Double door fridge - is it roomy enough? 4Sep 23, 2009 1:25 pm I used to have a side by side fridge/freezer when I lived in Europe and it was quite large (they do come in defferent sizes). It could easily fit 2 cases of beer on the bottom shelve (did I mention it was quite large). The freezer bit is a bit small (after loosing space for Ice maker) but you can probably buy them w/o icemaker as well Jack Most of the time, council will push you out to a private certifier as it ties up their limited resources. Where a builder has gone belly up, the certifier passes the file… 7 5381 As per title, unsure if my land doesn’t have enough fill. The house on the left seems to have higher elevation. Not sure if the empty lot in between has just been… 0 568 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 16158 |
