Browse Forums General Discussion Re: Removing Gyprock 2Sep 22, 2009 8:47 pm That’s a hard one to answer with any certainty. Was the original wall a polished finish? The rougher the texture of the render the more the glue will bite and probably cause damage. If it was a DIY job, they may have used liquid nails and a corking gun. (if so you may be able to scrape it off with a scraper and have minimal damage) I suggest you prepare for the worst, and hope to be pleasantly surprised. You could always pull off one sheet, and if its too messy just replace the sheet. 6 11122 The best advice is for you to get a competent building consultant to guide you through your build 7 4647 |
