Browse Forums General Discussion Re: Weathertex Braidwood Smooth - anyone used it? 3Sep 11, 2009 8:47 am Hi Jazz No worries at all. My parents used Weathertex on their house when they built a few years back and we liked the look of it. We also liked it because it's guaranteed not to split, crack or rot for 25 years. There are a couple of Weathertex looks you can choose from and they also have panels that interlock with each other too (called Primelok). From memory they come in approx 3 meter lengths and are about $22 per length. If you call them they are quite happy to send out brochures and samples to you or you can visit their website: w3ather t3x Edited by Onc_artisan I would probably render it and then paint it as per your other advice, or gyrpock over the top. 1 3345 As title suggests, looking at using the interlocking Pentablock stacked stone products to replace failing timber retaining… 0 17881 there is only 20% difference in concrete strength between 20 mpa and 25 mpa, so check with your engineer first if it fits his calculation tolerances. There are ways to… 6 18306 |
