Browse Forums General Discussion 1 Sep 01, 2009 11:24 am Hi all, What's the pros and cons of porcelain vs ceramic tiles? I am about to replace the waterline tiles in my pool and have found samples of both. Physically they look the same (same size, same 'gloss', both supplied on the mesh backing). The porcelain colour seems to run deeper throughout the depth of the tile which i think is one of the benefits. ie. longer lasting, less fading over time. but is there a preference over one or the other, particularly if fully submersed? Does the adhesive or grout used change depending on which one is used? Thanks Re: Porcelain or cermamic tiles? 2Sep 01, 2009 9:43 pm In short if the tiles are for a pool, ceramics will suffice easy to cut easy to lay although the mesh backing can be a bit of a nonsense. The trick with pool tiles is to work fast to allow for adhesive bonding and peeling off papers and properly alignment of those tiles if you are not DIY then it will be cheaper to get ceramic quotes. Firstly the ableflex that has been installed needs (manufactures specification) a sealant cap over the top, preventing water draining down between the slab and the… 3 7744 Our house was completed 8 years ago. Builder did not leave any spare roof tiles behind. Just found out that one tile is cracked. Wanted to replace the tile but most… 0 2774 1 15729 |
