Browse Forums General Discussion 1 Aug 31, 2009 11:24 am Hi Our front door has unfortunately got wet between installation and sealing and there is a small watermark a few inches above the base of the door. We are intending to seal the door with varnish, we just wondered how we could deal with this mark best? Thanks JB Re: How do I remove or disguise water staining on a timber door? 2Aug 31, 2009 11:27 am Do you know anyone with a chlorinated pool? Sodium hypo might do the trick... you don't need much onc_artisan Where you are coming from is where you are going to... Re: How do I remove or disguise water staining on a timber door? 3Aug 31, 2009 12:01 pm onc_artisan Do you know anyone with a chlorinated pool? Sodium hypo might do the trick... you don't need much onc_artisan Thanks - but what should I do with it? I could buy some from Bunnings if necessary. JB Re: How do I remove or disguise water staining on a timber door? 4Aug 31, 2009 12:11 pm You don't need much prolly less than 100ml... put a small amount in an atomiser and give it a little spray. Leave it on and then neutralize with more water ...and is why I mentioned any friends with a chl pool. onc_artisan Where you are coming from is where you are going to... Re: How do I remove or disguise water staining on a timber door? 5Sep 04, 2009 10:41 pm use a product called revivor from a dulux trade outlet, very cheap mixed down with water. It containts oxalic acid which is used to prepare timber products for staining/varnishing. This is the professional way used by painters. I do not know what effect sodium hypo would have on the timber/coatings but painters use oxalic acid. Re: How do I remove or disguise water staining on a timber door? 6Sep 05, 2009 6:25 am swarvy use a product called revivor from a dulux trade outlet, very cheap mixed down with water. It containts oxalic acid which is used to prepare timber products for staining/varnishing. This is the professional way used by painters. I do not know what effect sodium hypo would have on the timber/coatings but painters use oxalic acid. Thanks! I'll try that. I appreciate the other suggestion about sodium too I'm just not brave enough to use it, I think if Dulux recommend a product then they have some responsibility to ensure it works! JB Re: How do I remove or disguise water staining on a timber door? 7Sep 23, 2009 12:52 pm Place a tea towel over the mark and use a hot iron without water and place it on the tea towel until the mark is gone, this should suck the moisture out. Not sure if this will work with your front door, but it works with those water marks you get on wooden coffee tables. Re: How do I remove or disguise water staining on a timber door? 8Oct 03, 2009 1:00 am swarvy use a product called revivor from a dulux trade outlet, very cheap mixed down with water. It containts oxalic acid which is used to prepare timber products for staining/varnishing. This is the professional way used by painters. I do not know what effect sodium hypo would have on the timber/coatings but painters use oxalic acid. MASSIVE thank you swarvy - I used the reviva product today on the door and it worked a treat - door looks like brand new now. I've put a coat of varnish on so we should keep the weather out now. THANK YOU JB Hi, I have an area of zincalume cladding encasing a number of external downpipes. Unfortunately one of them has been permanently stained by some diluted phosphoric acid -… 0 907 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5947 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11839 |
