Browse Forums General Discussion 1 Aug 30, 2009 4:28 pm Hello Guys, I want to install Solar Hot Water system on my townhouse in Brisbane. Done few quotes and put this chart together. Like to share and see what people think and how it compares to what others have calculated: Like ⋅ Add a comment ⋅ Pin to Ideaboard ⋅ I assumed that 'small' system will still use electricity in winter at $50/winter. Larger are not going to use any. One additional graph is current electricity cost of electric system. EDIT: fixed PIC the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14059 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20233 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 |
