Browse Forums General Discussion 1 Aug 28, 2009 12:20 am Can anyone recommend a wired doorbell brand or where to buy them from ? Nothing fancy - just one that goes bing-bong and does not look too plastic ! Our (rather expensive) wireless model seems to be very temperamental and always needs new batteries at the most inopportune times. Re: Wired door-bell 3Aug 29, 2009 10:18 pm Bunnings. You will need a transformer that converts to the 6 watts or what ever it is. That is hard wired to your 240v by the leccie. Then you need the button, some classey ones available... and some arsey ones too The wire of course, and the bell. It is all bought individually and there are a few brands to choose from. Go to the door bell isle. Pick what you want. Then press every demmo bel they have and walk away Re: Wired door-bell 5Aug 29, 2009 11:08 pm Fu Manchu *shudder* Bunnings. You will need a transformer that converts to the 6 watts or what ever it is. That is hard wired to your 240v by the leccie. Then you need the button, some classey ones available... and some arsey ones too The wire of course, and the bell. It is all bought individually and there are a few brands to choose from. Go to the door bell isle. Pick what you want. Then press every demmo bel they have and walk away Thanks for the explaination as when I ordered mine in dad asked as to why I needed a transformer, I told him that I did as that's what the salesman said Re: Wired door-bell 6Aug 29, 2009 11:09 pm Well it is only the bell exposed to the elements. very low voltage and weather proof more or less. The transformer goes in the roof, the wiring in the wall cavity, the bell can also go in the roof space or anywhere convenient and out of sight. Pantry or linen press or cupboard or where ever really found this too Remember the old winding door bell. http://www.waggarestorationcentre.com.a ... 20a&page=3 no batteries, works everytime, just like Nanna used to have Re: Wired door-bell 7Aug 29, 2009 11:12 pm check these out too. http://www.friedland.co.uk/en-GB/produc ... fault.aspx Thanks for your thoughts. Do you feel your louvre sidelite security mesh is safe? I was thinking no window at all so no one can see if I'm near the front door, shadows… 2 662 Black on light wood does look good. Not sure if it will be as long lasting as a steel finish? 6 6353 I’m in a similar position except I’m after sliding 3 stacking doors. I am on a second-story apartment of which the balcony would not adequately fit any bi-fold or… 5 16156 |
