Browse Forums General Discussion 1 Aug 27, 2009 11:51 am Hi , Iwas wanting to dig a large hole around the storm water PVC pipe and pour a concrete sump so that I could then use a sump pump and draw off that beautiful rainwater to fill be gigantic 15,000 litre tank. Has any one used a sump before ? Suburbia is where the developer bulldozes out the trees, then names the streets after them. Re: Rain Water Concrete Sump 3Aug 31, 2009 11:08 am OK, After lots of phoning around, this is what I have come up with: (1) 600x600x1200 40MPA concrete, F72 mesh concrete pit + checkerplate cover: $900 (incl GST) delivered (2) Daveys D25A sump pump: $545+GST (3) Dig pit for sump installtion, trench for pipe laying and pipe installation: ? (4) Run a 240V external line for the sumppump : ? Am still trying to get info... Suburbia is where the developer bulldozes out the trees, then names the streets after them. Re: Rain Water Concrete Sump 4Aug 31, 2009 11:31 am xanthrope - I have PMed you with a link to some tanks we built for fish keeping (trout) http://www.backyardaquaponics.com/forum ... 78#p200778 They were 32mpa and don't leak they are about 8000ltrs each and poured monolithic. Hope this helps onc_artisan Where you are coming from is where you are going to... Re: Rain Water Concrete Sump 5Nov 04, 2009 10:42 am http://www.dtbpumps.com/rain_return.html Buy a rain return from these guys. Sump and pump in one. About $1100. You need a float switch to go from the sump to the tank so it stops pumping when tank is full. Re: Rain Water Concrete Sump 6Nov 05, 2009 8:16 am I just build a concrete sump yesterday. I will post some photos when I get them. My sump is going to be used for my paving run off which is not good for the rainwater tank because of debris. You only need a sump if your block is lower than the street, to pump the water up hill. My downpipes are connected straight to the rainwater tank, and overflow goes to the street, you dont need a sump to do this as the rainwater tank is higher than the street, and water flows downhill. Can a plumber put a tap on a rain water tank which is full? Tank is similar to one in photo. Cheers. 0 1663 Hi, does anyone have any experience with using Trex rain escape or EPDM rubber to waterproof a deck so you have dry space underneath. Popular in the US and realize that… 0 3422 Yes you are correct, unless there are outside works which form part of the contract such as landscaping or driveways, and importantly, the work delayed is on the critical… 1 3507 |
