Browse Forums General Discussion Re: What % do builders charge on cost plus commercial building 2Aug 23, 2009 7:56 pm I think you will find a sliding scale Cost plus = the cost, plus a margin The margin can be as little as 7.5% or upto 25% depending on how much you're able to pay / charge I say sliding as volume is the key onc_artisan Where you are coming from is where you are going to... Re: What % do builders charge on cost plus commercial building 4Aug 23, 2009 8:24 pm That is just too broad ie tilt panel, brick, steel. Prolly some suggested uses could help to define a bit. ie hairdresser(plumbing prelay) - heavy haulage(thickenings), They could be, being fair and cheap, or unfair and expensive Are the units larger than 175 sq mtrs each?? onc_artisan Where you are coming from is where you are going to... If you already have a contract, is the inspection cost stated in there? If not they would be forced to issue you a variation which you could of course object to. 12 26078 1000000% definitely add insulation. I have in my home and it makes a big difference minimising sound transfer. Insulation is pretty cheap and definitely worth it 2 6394 We are building a house that was planned to be clad in Hardie Linea, our builder has now requested to swap this for BGC Nuline Plus. They look fairly similar and he has… 0 887 |
