Add old "driveways, paths and garage floors" to the list of things to check before doing any work. Actually given the constant wear from tyres and feet they probably should be checked anyway.
http://www.abc.net.au/news/stories/2009 ... 663509.htm
Browse Forums General Discussion 1 Aug 22, 2009 11:25 am Add old "driveways, paths and garage floors" to the list of things to check before doing any work. Actually given the constant wear from tyres and feet they probably should be checked anyway. http://www.abc.net.au/news/stories/2009 ... 663509.htm Re: Asbestos 2Aug 25, 2009 2:06 pm Old carpet underlay. http://www.abc.net.au/news/stories/2009 ... 665634.htm Re: Asbestos 3Sep 12, 2009 10:28 pm Our house was built in 1981 and has asbestos products in it. We had asbestos sheeting removed from the bathroom and eves, and we think one of the boundary fences is asbestos as well, but it is painted and in good condition. So be careful renovating even if your house was built after the 1970's. They abviously knew by 1980 that they shouldn't be using it. Re: Asbestos 4Feb 13, 2010 5:24 pm Warning issued about imported decorative wall tiles. http://www.workcover.nsw.gov.au/Documen ... s_2390.pdf Re: Asbestos 5Feb 13, 2010 5:48 pm Asbestos was used to 1978... I know builders that were using it Also, building hardwares we reluctant to return stocks so continued to sell it after then. A test called the 'pulloff' test where you attach a piece of sticky tape, cut a cross (X) and remove the tape. Then take this to the lab to be checked. Where you are coming from is where you are going to... What you are looking at is fibrous plaster, true gypsum, it is cast on horizontal beds with fibers included to give strength. I has no Asbestos in it. Houses before 1985… 2 7142 4 1844 |
