Browse Forums General Discussion 1 Aug 17, 2009 1:37 pm We have some tree in our land that we'd like to remove befor building. Called up a tree removal company, and was told to have a landscape plan, building plan and need to apply the permit ourselves. Is it the normal process ? thanks Re: removal tree procedure 2Aug 17, 2009 2:05 pm in our case our development application with the builder showed the location of trees which needed to be removed in order for the house to be built - so with the D.A approval came permission to remove the trees concerned, worked for us. DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 6337 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6713 PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10256 |
