Browse Forums General Discussion 1 Aug 17, 2009 12:57 pm We are currently renovating our house and a couple of rooms have wallpaper. A steamer should take care of one room but in another it looks like the wallpaper has been painted over. I vaguly remember reading somewhere that once you paint over wallpaper you can't get it off. Is this true? Is there any way to get the wallpaper off? Re: Wallpaper removal 2Aug 21, 2009 12:50 pm dstann We are currently renovating our house and a couple of rooms have wallpaper. A steamer should take care of one room but in another it looks like the wallpaper has been painted over. I vaguly remember reading somewhere that once you paint over wallpaper you can't get it off. Is this true? Is there any way to get the wallpaper off? The best option would be a few good quality, sturdy and sharp paint scrapers and a handful of mates over a weekend. Make sure to fire up the barbie and have lots of patience. If it's on a brick wall - you might do some damage to the plaster, which will need to be repaired correctly before re-painting. If it's on plaster board - you might be better off ripping it all out and replacing it, if it's only one room. Re: Wallpaper removal 4Aug 21, 2009 9:58 pm dstann We are currently renovating our house and a couple of rooms have wallpaper. A steamer should take care of one room but in another it looks like the wallpaper has been painted over. I vaguly remember reading somewhere that once you paint over wallpaper you can't get it off. Is this true? Is there any way to get the wallpaper off? Try using a heat gun and slowly peel it off the wall with a scraper Re: Wallpaper removal 5Aug 21, 2009 10:14 pm grinder dstann We are currently renovating our house and a couple of rooms have wallpaper. A steamer should take care of one room but in another it looks like the wallpaper has been painted over. I vaguly remember reading somewhere that once you paint over wallpaper you can't get it off. Is this true? Is there any way to get the wallpaper off? Try using a heat gun and slowly peel it off the wall with a scraper In our case ... A steamer made no difference to the really stubborn stuff. A heat gun seemed to improve things slightly - may have been a placebo effect though. Soaking with a hand held spray gun was effective (but won't work in your case with the layer of paint to contend with). I think try them all and see what works best (at least better than banging your head against the wall). You might even try a paint stripper to thin out the layer of paint and that might let you get to the underlying wallpaper a little easier with one of the above methods. Prepare for the worst i.e. that it could take you 3 days. Persist and it will be worth the effort. Good luck. DIY, Home Maintenance & Repair At a bit of a loss on this one - we're thinking the original owners never removed the protective laminate covers from their kitchen cabinets after installation and in the… 0 6328 Hi, planning on using the attached stone pieces in my bathroom. I want to remove stains and gloss seal. Can I get some advice on best way to remove stains and best… 0 6700 PM me your email. I have a build excavation calculator you can use based on your plans to double check what your builder is telling you. Cheers Simeon 1 10207 |
