Browse Forums General Discussion 1 Aug 17, 2009 11:58 am After this weekend's wind storm did anyone's house suffer any material damage? We lost a front door closer (those spring loaded things at the top of the door) when the wind blew the door wide open as we were letting guests in. The front gutter was being pulled off the facade, and most likely we lost a few nails there. The front artificial turf went for a few rounds as well. What was hilarious though was the poor workers on the nearby school that's going up. They were still digging away (no water trucks) and every few minutes a dust storm would brew up. I'm sure there was some OH&S issues there... Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 7816 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 6846 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10479 |
