Browse Forums General Discussion 1 Aug 14, 2009 9:18 pm Hi, I really need some help. We are thinking about buying a house that has been rented for a few years and they have trashed the floors. The bedrooms and lounge is carpeted but the hall, dining, kitchen and enterance is tiled on top of timber a timber floor. It is probably only 15 to 20 square metres of tiles and every about 2nd tile is cracked. Want to do it DIY to save some money. Any ideas???? Re: How do I remove tiles layed on a timber floor???? HELP 2Aug 14, 2009 10:48 pm Gday, use a jackhammer with tile removal blade very carefully. Try not to let the steel blade contact the timber surface too much as it will leave grooves/marks that may not be repairable. If the tiles stick to the floor too much you can try heating the top of the tile with a gas burner attached to a gas bottle. Before you start any of this try a hammer and coal chisel to see how easy they come off first so you can decide which is the correct equipment to hire.. I think Kennards concrete care hire the burners from memory. The heat applied to the tile surface will cause it to crack and allow easier removal. If the tile adhesive does not come off with the tile this will need to be removed with a timber floor sander to get it back to a bare timber surface. If you are saving $$ removing the tiles etc yourself spend the $$ saved on getting a professional to sand the timber floor and apply a good sealer. Regards Steve Re: How do I remove tiles layed on a timber floor???? HELP 4Aug 17, 2009 11:27 am onc you have removed a tile or 2 manually, use a flat shovel horizontally to scrape underneath the tile. This will probable do less damage that the jackhammer Adrian B Re: How do I remove tiles layed on a timber floor???? HELP 6Sep 04, 2009 9:48 am i just spent yesterday removing tiles, getting those floor tiles off wooden floors is hell, they us some sort of balck sticky glue, I only had to remove about 2 square meters of floor tiles and I still havent finished the only system that seems to work is to hit the tile multiple times with a hammer and lift the bits of tiles out as they break. If anyone can suggest a better way im all ears How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5947 the step up is 30mm and wanting it to be flat . how much does the concrete have to be lowered .we plan on removing bath and lenghten shower and adding seat. the old bath… 0 11838 You have no photo with your post. Best I can say is to remove an A&L flyscreen don't be afraid to distort the frame almost like a trapezium. It doesn't take a lot of… 1 7077 |
