Browse Forums General Discussion Re: brick footings 4Aug 03, 2009 6:12 pm No offence buildflex Good question Pat. Brick footings could be brick piers. You need to find the source of the problem before you consider major works, or it could be wasted. Where you are coming from is where you are going to... 2 8366 I should have followed up on this thread. So, the pier foundation wasn't large enough on the side it was leaning towards, and the NBN cable went through the pier, just… 8 12130 Just be careful with building stability during construction, that is when the structure may be weakened, refer to your engineering drawings for stability methodology. 1 7231 |
