Browse Forums General Discussion 1 Jul 30, 2009 5:29 pm We my DD deicided to put a tin of white waterbased put behind the tyre of my car yesterday, and of course i didn't hear it...after a bang pop kerslpatt i discovered i had ran it over and it exploded of our black pavers! Have got most off using a pressure cleaner but still have bits that it wont get off...does anyone know of anything that will remove the paint? Thanks so much in advance! Re: Removing water-based paint 2Jul 30, 2009 5:41 pm i'd usually say turps.. but not sure how that'd affect the pavers! Aussie Alfresco Ultimate Bertram, WA Homebuyers Centre WEEK 21 - Practical Completion (Scheduled) My Build Thread - https://forum.homeone.com.au/viewtopic.php?f=31&t=21383&p=278506#p278506 Re: Removing water-based paint 3Jul 30, 2009 5:47 pm Metholated spirits will dissolve water based paint. Cheers PP Re: Removing water-based paint 5Aug 04, 2009 11:44 am If you don't have any luck with meth spirits or turps, try going to Bunnings and getting their grafitti paint remover. We had to remove paint samples we used on our brick wall and this stuff got most of it off. You had to scrub at it with a wire brush. Re: Removing water-based paint 6Aug 04, 2009 11:52 am This will be a tough fix, but if you use a solvent you will spread the residual Would it be possible to remove a brick at some point? Then you could turn the pavers over and they will be good as new Onc_Artisan Where you are coming from is where you are going to... Hi We are building in the Hunter Valley, our soil test is H1, our builder has advised us they need to have a letter signed for Fair Trading as the new drainage standard… 0 3552 thanks. the above one is white Mat tiles and have gripness so going for this Mat tiles for both indoor and outdoor. Beaumont told it can be used in both indoor and… 2 1680 6 11152 |
