Browse Forums General Discussion Re: Are Independant Inspectors Worthwhile? 21Aug 06, 2009 5:54 pm In answer to your question , Are Independent Inspectors Worthwhile? Yes they can find problems that you may not, but they have no power to enforce them. In fact, many forum posts state that the builder either doesn't fix the problems at all, or just patches things up. Then of course you have to get another inspection to prove that the work is still not done. This can go on and on. You can bring most problems to their attention in writing and don't forget registered post too Re: Are Independant Inspectors Worthwhile? 22Aug 07, 2009 9:44 am Thanks Zaphod. I might have to do both - Get an II and put it in writing to make sure something happens Building 'The Kingston' (with 'Boston' elevation) through Blueprint Homes in Hocking, Perth **PCI complete 06.02.10** My Thread - https://forum.homeone.com.au/viewtopic.php?f=31&t=17607 Re: Are Independant Inspectors Worthwhile? 23Aug 08, 2009 10:21 am zaphod Independent Inspectors...........but they have no power to enforce them. II's do not have the power, however BACV and VCAT do. Have a read here http://qaireporting.com.au/your-legal-rights Re: Are Independant Inspectors Worthwhile? 24Aug 08, 2009 11:02 am NatB Thanks Zaphod. I might have to do both - Get an II and put it in writing to make sure something happens Just steer clear of Ar...c...re and Mr B....J... in Perth. He charged more than the others I talked to, mis-diagnosed a problem with timber in the bottom plate and didn't bother to check anything else properly. I ended up forking close to $500 for a worthless report. Chris My father rode a camel, I drive a car, my son flies in a jetliner, his son will ride a camel.Saudi saying Re: Are Independant Inspectors Worthwhile? 25Aug 10, 2009 10:15 am Thanks Kristof. Are you able to PM me the names of those II's? Building 'The Kingston' (with 'Boston' elevation) through Blueprint Homes in Hocking, Perth **PCI complete 06.02.10** My Thread - https://forum.homeone.com.au/viewtopic.php?f=31&t=17607 Re: Are Independant Inspectors Worthwhile? 26Aug 10, 2009 2:37 pm Tornado_ALIVE zaphod Independent Inspectors...........but they have no power to enforce them. II's do not have the power, however BACV and VCAT do. Have a read here http://qaireporting.com.au/your-legal-rights Many people on this site have given up, due to the inability of these groups to force the builder to repair the brickwork. legal action is long, expensive and often results in an unfavorable outcome. Re: Are Independant Inspectors Worthwhile? 27Oct 27, 2009 9:46 pm Tornado_ALIVE Not in your area but worth a read. http://qaireporting.com.au/ Under the 'Services' tab it will quote you prices. Check out their case studies under the 'case studies' tab. It is a very interesting read and are examples of inspection reporst they prepare for you to submit to the builder. Looking at this I am definatly getting an II I just found out today that a Builder we personally know in Perth also does inspections. If he build out of Perth we would have used him as our builder. He is based NOR. PM me if you want details and the web site. Re: Are Independant Inspectors Worthwhile? 28Oct 27, 2009 10:21 pm zaphod Tornado_ALIVE zaphod Independent Inspectors...........but they have no power to enforce them. II's do not have the power, however BACV and VCAT do. Have a read here http://qaireporting.com.au/your-legal-rights Many people on this site have given up, due to the inability of these groups to force the builder to repair the brickwork. legal action is long, expensive and often results in an unfavorable outcome. From what I've read, "Many people on this site have given up" is not what I'd say. My experience also is more positive than Zaphod appears to have experienced. Following the report from our independent inspector, brickwork was removed, our slab, where it had blown out, was cut back, and the brick work was redone. Quite a lot of work was done on the frame, too. Perhaps it is a question of addressing issues early enough for them to be realistically addressed? Our independent inspector certainly found serious defects that I did not spot. Is there an experience that has led to your negative view of inspectors, Zaphod? Pfiff Finally making progress again, with a clothesline (yippee) and some much needed little things being attended to over the holidays. 40 C on New Year's eve? We love our a/c! Re: Are Independant Inspectors Worthwhile? 29May 29, 2011 12:27 pm I always get a building inspection done when I buy a house I think it is important to know what you are getting yourself into when there is a lot of money at stake. Having said that I have had reports that just stop short of saying that the house should be condemned. On further examination of the report and pumping the inspector to explain exactly what he meant it turned out that he was only covering his arse. If we had not asked for an explanation from him and just taken the report at face value we would of not gone ahead with the sale and potenially lost hundreds of thousands of dollars. That was in our renovation phase. Recently we have had experience with Archicentre and one of their 'building inspectors' and their blatent 'covering their arse' report. Just as an example saying that the pool and stairs are not compliant to council standards, without even checking with the council (and they are have the paperwork to prove it). Also saying that the Solar Hot Water System is 'held together with wire' when actually it is partially covered with carpet because it heats up quickly and needs the overflow to be stopped (waste of water etc) obviously in great working order. This all from a ground floor view didn't even get on the roof. So in short it is important to get a building inspection and it is also extremely important to question that report to make sure that it is telling the truth and not just an exercise in 'covering their arses'. After all you paid alot of money to have it done. Re: Are Independant Inspectors Worthwhile? 30Jun 04, 2011 7:08 pm Hi I think an inspector is worth while. We are using one for our build in Melbourne. We just don't have enough knowledge to keep them honest on our own and we certainly don't trust them to be honest. Hopefully independent inspector = better quality finish. That is a really good attitude Akin to you catch more flies with honey than vinegar. I do enjoy watching that tik tok inspector from Victoria but he does go a little… 12 81896 If you are in Victoria you have a statutory right to your own building inspector regardless of builder's consent. No negotiations are required. However the builder will… 1 2943 |
