Browse Forums General Discussion Re: total redo of an old apartment - advice on best sequence 2May 24, 2007 5:40 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: total redo of an old apartment - advice on best sequence 5May 24, 2007 11:16 pm Everything looks in order to me.
I guess its all about good planning, so no matter what order you do things, as long as you have your planning spot on, you will be fine... Regards Michael Doors Plus, No Fuss... (VIC) Re: total redo of an old apartment - advice on best sequence 6May 26, 2007 2:14 pm Thanks for all the replies, guys.
Steve, doing windows later makes sense. Also putting in the retention wall before floorboards makes sense too. I just thought that I could erect a wall over the floorboard for some reason. Seems ridiculous now that I thought about it. The apartment is rented at the moment. But I will move in within a few months. Probably stay there for a few years until I can afford a big house. One of my big concerns about this project asbestos. I was planning to do a large part of it myself - removal of kitchen, removing carpet, putting in floorboards, knock down the retention wall, etc. But since it's an apartment built in the 60s, there could be asbestos behind the kitchen wall, etc. Are there professionals that would remove walls and kitchens when there could be asbestos involved? Re: total redo of an old apartment - advice on best sequence 7May 26, 2007 3:24 pm Jinster One of my big concerns about this project asbestos. I was planning to do a large part of it myself - removal of kitchen, removing carpet, putting in floorboards, knock down the retention wall, etc. But since it's an apartment built in the 60s, there could be asbestos behind the kitchen wall, etc. Are there professionals that would remove walls and kitchens when there could be asbestos involved? Asbestos is mainly present in fibre cement sheeting and some floor coverings. Best bet would be to remove some samples and send it to a lab for testing. If the sheeting is present in the house it is possible and still legal to remove yourself but you need to take a number of precaustions such as sealing off the affected room, wearing disposal overalls, p2 respirator mask and removing the sheets with minimal breakage and wrapping in a thick plastic and taping before being places in a bin to be removed by an asbestos removal. Like wise you can still work on it but you have to be careful not to damage the sheeting and reseal any exposed fibres. I'd look at removal and replacement of the sheets. You might remove the old kitchen to find it had been glued to the cement sheeting and you've damaged large sections of it beyond repair. You can always employ someone remove it for you, but expect it to cost quite a bit of money. Re: total redo of an old apartment - advice on best sequence 8May 28, 2007 9:47 am Asbestos depends largely on where you are.
In Brisbane, for instance, you need to be licensed to remove more than 10m² of asbestos. We were quoted $4500 to have 3 rooms worth of asbestos removed. After a bit of research, my partner enrolled in the 4 hour, $150 course in order to obtain the licence. You need a separate license to transport asbestos, so we're getting a special skip to remove ours. Good luck with it! Lotte Re: total redo of an old apartment - advice on best sequence 9May 28, 2007 12:47 pm What is a retention wall ?? Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: total redo of an old apartment - advice on best sequence 10May 28, 2007 1:10 pm I wasn’t game to ask! Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: total redo of an old apartment - advice on best sequence 11May 28, 2007 1:23 pm I hope it's nothing simple
How's the hard Drive Michelle ? Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: total redo of an old apartment - advice on best sequence 12May 28, 2007 1:31 pm What a nightmare that was!!!!
Had to get a new one and everything had to be loaded onto it. I’m still trying to sort it all out. I hope this one hangs in for a few years I don’t want to have go through this again in a hurry!!! The only retention wall I know of is in the yard, for soil…… But yes, I hope its nothing WE should know about. Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: total redo of an old apartment - advice on best sequence 13May 29, 2007 10:18 am I assumed he was talking about a heat retention wall or a stubb wall - but then assuming is not the best thing is it.
Maybe Jinkster can fill us in on what he is describing? Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 17303 Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4896 Thanks Chippy,I do have one that I levered out. I'll try to find a brand name on the windows then do some searching. Here is a photo where you can see how worn they are. 2 7953 |
