Browse Forums General Discussion Re: total redo of an old apartment - advice on best sequence 2May 24, 2007 5:40 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: total redo of an old apartment - advice on best sequence 9May 28, 2007 12:47 pm Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: total redo of an old apartment - advice on best sequence 10May 28, 2007 1:10 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: total redo of an old apartment - advice on best sequence 11May 28, 2007 1:23 pm Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Re: total redo of an old apartment - advice on best sequence 12May 28, 2007 1:31 pm Internal and External Building and Colour Consultant Online - Worldwide http://www.denovoconcepts.com Re: total redo of an old apartment - advice on best sequence 13May 29, 2007 10:18 am I assumed he was talking about a heat retention wall or a stubb wall - but then assuming is not the best thing is it.
Maybe Jinkster can fill us in on what he is describing? Versaloc is a mortarless besser block system that still needs a properly engineered footing. If you just do a 400x200 footing it will fail in time. At 17m long you need it… 1 17749 Is it possible to render an old corrugated iron shed.I have heard that it can be done if it is covered with chicken wire first.Not sure of the ratio of the render mix and… 0 4896 Thanks Chippy,I do have one that I levered out. I'll try to find a brand name on the windows then do some searching. Here is a photo where you can see how worn they are. 2 7958 |
