Draftsmanship work
Just a quick question - I've had a search through the forums and couldn't find specific info on this so apologies if this is a dumb question!
We have just asked a builder/draftsman to draw up some plans for a renovation/extension on our house. We're adding a couple of bedrooms, a 2nd living area, and an ensuite.
We've been quoted just under $6k which includes plans for the existing site, liaising with council to ensure plans are compliant, and then a quote (time/cost) for the work.
Is this about right?
thx
The quote does include 2/3 revisions, elevations, specs for finishes, and a qualified cost for going ahead with building the plans
When we were getting quotes from draftsmen, we had some say that it would cost as high as $8000 pftt i don't think so!
So I would recommend hunting around and see what other draftsmen say.
The other thing is, if he's a builder/draftsman..who owns the drawings when their done?
Surely your going to tender your reno to a number of builders to get a competitive price?, will he release the drawings to you to do this??
Just a thought,
Pat.
Good point Pat - I'll ask about ownership
thanks all for your input
I would imagine that price would include engineers drawings, 5 star energy, plans and permits.
Mine doesnt include 5 star or engineering
Wow. 5 star is cheap but engineers def are not!
Did you get them done by a draftsman or an architect?
We're building on stumps. And our alfresco is square two sets of bifold doors without a support between them, so Im assuming we will need a beam of some sort, which is why we need engineering? I dont know, cant say ive looked in to it yet...
What do you need a structual engineer for? Are you building on a slab?
A structual engineer is required for all new builds.
Who does the bracing plan for the structure? Drafty doesn't do this.
Without a engineers report no builder can build a house.
What about lintels that have opening that bear girder trusses?
Who guarantees the structual integrity of your house? Not the draftsman!
Well said Minx,
I for one will not gaurentee or even acknowledge anything structural on a build....'to structural engineers drawings and specifications' everytime. Be wary of builders and drafties...or anyone else for that matter, who say you dont need an engineer.
Please be aware people...a reno or new build is a huge financial and emotional undertaking...dont skimp on the basics (and structural engineering is a 'very necessary' basic). The initial outlay is minimal in comparison to the price of the build...the cost far outweighs the possible rectification cost needed if your build starts to sink/fall apart/fall down etc etc.
Just a thought,
Pat.
It depends what it includes really. If he is going to draw up the existing and proposed plans and elevations then also submit them to Council for the DA then its not bad. However if you are doing a full DA you will also need the CC submitted to Council or Private Certifier. Also depending on the detail in the drawings its hard to get an accurate quote which could leave you open to lots of variations from the builder. Good luck though.
So who knows......
5
I posted the floorplan on Houzz.com forum and got some really good ideas and advice from people there. Then we reached out to a couple of renovation companies and one…
25/02/2024
1) I had requested R6 ceiling insualtion batts, however I noticed that on some areas there are huge gaps which will allow hot air to sweep in, and also noticed black/grey…
16/04/2024
1
could be the footing or being hard up against the other wall with no expansion joint or both. You could try again with brick mesh and use some sticky back foam against the…
