Browse Forums General Discussion 1 Jul 22, 2009 10:35 pm can anyone advise me how to remove a stain on my blackbutt floor from a permanent marking pen? I've tried various cleaners but none of them have worked or even lessened it. The finish is synteko 2 part water based polish with a satin finish. Re: removing stains from blackbutt floor 2Jul 22, 2009 10:45 pm Tooth paste Be gentle Where you are coming from is where you are going to... Re: removing stains from blackbutt floor 4Jul 23, 2009 11:27 am Just recently I had to remove permanent marker from my dining table. It is varnished rubber wood. I used hair-spray and it came out (I had googled "how to remove permanent marker from wood") then a little rub with toothpaste. It's completely gone!! Before I try anything though, see if you can test in an inconspicuous area, just in case it reacts badly with your wood. Good luck. Re: removing stains from blackbutt floor 5Jul 23, 2009 1:34 pm From the supermarket you can buy a sponge called the Chux magic eraser. You moisten the sponge and rub gently over the marks. These can be used on ovens, walls, wood etc. They are chemical and detergent free. I would be trying something like this before you start applying chemicals. Re: removing stains from blackbutt floor 6Jul 23, 2009 6:15 pm I 2nd the magic eraser they are fantastic Re: removing stains from blackbutt floor 7Jul 23, 2009 8:18 pm yup definitely magic eraser Building with Homebuyers Centre El Questro! My building thread..viewtopic.php?f=31&t=19421 Brickies started 5/10 Hi everyone, Have just put a shower in the laundry and after only using it 2-3 times have noticed staining on the grout. The tiles were glued onto a concrete wall after… 0 5453 6 11152 The best advice is for you to get a competent building consultant to guide you through your build 7 4687 |
