Browse Forums General Discussion Re: Neighbour noisy air conditioner - condenser unit 21Jan 28, 2011 11:49 pm ^^^^ +1 Paul p you have admitted that it's you that has the problem with the noise rather than your DD, my advise would be to turn up your TV or buy some earplugs. Noises such as a reg air con units aren't detrimental to kiddies.....why do you think the midwives/mothercraft nurses tell new mums to carry on with housework as per normal i.e. vacuuming, washing etc & not to tippy toe around??? Maybe your DS is picking up on your stresses hence he too doesn't like noises. FTR i have never heard of a curfew for air cons.....loads of perthites run theirs all nite thru on a hot nite. Cooper's Build - Perth NOR viewtopic.php?f=31&t=30525 Prelim- mid Sept 2009, Pre Start 2 Feb, Siteworks- 21 April 2010, Slab- 10 May, Deliveries- all by 26 May Bricking- 28 May - 26 June, Roof complete 5 Aug, Float 28 Aug, Lock up 16 Sept Cabinets 1 Oct, Tiling 22 Oct, PCI 18 Nov, KEYS 3 Dec 2010 MOVED IN 17 DEC 2010 Hi, I have a double and whenever the wind picks up I can hear alot of banging in certain areas of the house. I've had a look round and can't see any obvious issue but… 0 10652 DIY, Home Maintenance & Repair Thanks Chippy . Did also see a YouTube video before. Removed them . Thanks again for the advice. 2 13986 I had an old shower unit that broke on me and when I took it off, there were only 2 water pipes, instead of the normal 2 water pipes and a shower head pipe. S o I… 0 36979 |
