Browse Forums General Discussion 1 Jul 15, 2009 4:02 pm Hi, My architect is great but sometimes he doesnt listen to me maybe because I am young and a female, or maybe because he thinks I am spoilt (I dont know). At the start I made him aware that the stairs 'void' area (open air) on the 2nd level is not included in floor sace and made him ask the council and I was right! I know that the garage (upto a certain number) is not included in the floor space, stairs, neither is the alfresco or balconies. That is all fine BUT my architect has said that storage space is also not included in the floorspace but only on the GROUND floor! I dont understand why a linen cupboard/wardrobe upstairs (in the lounge area or hallway or wherever) IS included in the floor space ratio. He said only on the ground floor is the storage NOT inlcuded and on the 2nd floor it is included and therefore takes away from my floor space! Anyone know if this is true??? I want to make sure it is 100% the maximum floor space we are allowed to use. DA approved Waiting on a few more Builder's quotes. Re: Area's of a home NOT included in the floor space (ratio) 2Jul 15, 2009 4:10 pm Wow my original post is confusing. Basically does anyone know if your linen/storage wardrobes (on 2nd level) are included in your floor space or excluded?? DA approved Waiting on a few more Builder's quotes. Re: Area's of a home NOT included in the floor space (ratio) 3Jul 15, 2009 5:53 pm Yep, everything contained within the external walls of your house & maybe all or part of your garage, depending on your council. In our case, square metres greater than 40m2 had to be included in the floorspace ratio. So if teh garage was 50m2, only 10m2 would be included in the floorspace ratio Hope that makes sense. Built the Eden Brae Cambridge 34 Family with Boston Corner Facade Re: Area's of a home NOT included in the floor space (ratio) 4Jul 17, 2009 10:01 am Usually cupboards are included in the FSR regardless of what floor level they are on. Only time you may get away with it is if you have a storage area included in your garage. Why dont you ring the council ? CDC Housing Code 3 When to apply Floor Area external face of wall vs Gross Floor Area internal face of wall. Reading thru CDC Housing Code 3, lets take a lot 915sqm.… 0 16553 hey there! π so, itβs kinda common for standard drawer depths to be around 500mm since most cabinets use this size to fit the usual runners… 3 20903 You can really use anything you want the main consideration would be how it looks once painted/finished - or the look you want. Cabinetmakers use MDF because its cheap… 2 9959 |
