Browse Forums General Discussion 1 Jul 05, 2009 9:29 pm Hello. We're building a new house in southern Tassie, and are in the process of looking for a heat pump hot water system. We're a family of five, so need something sizable. We're coastal on the south of the island, so need something which will withstand sub zero temps on occasion. We're not that concerned with noise, as there are no bedrooms near the hot water location, and no neighbors in ear shot. Does anyone have experience, both positive and negative with the various options in cold climates? As I don't know a lot about hot water systems, by gut feeling is to stay with the large manufacturers, such as Rheem and Solahart. Ta, Matt. Re: Hot Water heat pump in cold climate 2Jul 05, 2009 9:40 pm We have a dux 250gal it is a bit noisy... only had it 9 months It was an upgrade from a woodchip hws won by the cheese n kisses Aeroheat... Not sure of the cost to power it but the water is hot best win ever Where you are coming from is where you are going to... Re: Hot Water heat pump in cold climate 3Jul 06, 2009 9:18 pm Dux have a new sub-zero version just released. I was hoping to go to the intro session at work but I was away on holidays so missed the info about it. It'd be worth a shot chatting to a local plumbing supplies about it though or even check out the Dux website to see what they can tell you. I have heard the normal heat pump can have issues in the colder climates not working efficiently. These new ones are meant to over come that. Possumchops Now the proud owner of 3.7acres of Serenity. Colour selection completed! Soon to go to council. Depends how much direct sun it gets. Is there any shading (eaves or trees)? If the sun hits a window directly it doesn't matter too much if it's double or single… 1 10108 18 74805 Hi guys, I want to butt a concrete vegetable garden bed against a concrete build up of a carport. It will be a 700mm high wall about 120mm thick and I will run a 12mm rio… 0 864 |
