Just have a urgent question:
What is the cost of your slab of H-D level of 23 squares?
The construction company will charge me more than 17,700.I think its too much.
Any good point for me?
Thanks
Browse Forums General Discussion Re: Urgent:what is the general cost of your slab? 3Jun 19, 2009 3:13 pm Our house is 23 squares, soil classification is M, block is flat, steel frame house, and we were charged $41899 for the foundations. That was the first construction installment after the slab was laid. Is that the question? - 17,700 is way cheaper Re: Urgent:what is the general cost of your slab? 4Jun 19, 2009 3:25 pm I just created a thread later on today, and for a 41square with a HD waffle type 3, engineerd slab we've been told WORSE CASE $5,975. I'm not sure of the differences between the 2 slab types but that's what is in our contract. Greg P.S Helyn, that's your construction installment, that's not the cost of the slab. Our house thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=18335 Re: Urgent:what is the general cost of your slab? 6Jun 19, 2009 3:33 pm Yes, I thought it couldnt be right but we paid that when the slab was laid and all that was done at that stage was scraping of the land and laying of the slab, what else does that installment cover then? How do you know how much just your slab cost?? (I think I should keep out of this; I really dont know what I am talking about ) Re: Urgent:what is the general cost of your slab? 8Jun 19, 2009 4:32 pm But they have different levels. The standard is M level and then H,then H-D so its reasonable to charge more than 17000 to build a H-D concrete slab? But one of friends said he only need to spend 12000 on it. So i was confused. And I have no idea on this at all,and want someone to help Re: Urgent:what is the general cost of your slab? 9Jun 19, 2009 11:29 pm Wowo.. We must be getting the bargain of the century for a 41sq house, type HD slab for $5,975? That's not extra, that's total price of the slab as quoted in our price break down. We were originally quoted $3,900 and I actually questioned the $2,000 price increase. Our house thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=18335 Re: Urgent:what is the general cost of your slab? 10Jun 19, 2009 11:34 pm GSK Wowo.. We must be getting the bargain of the century for a 41sq house, type HD slab for $5,975? That's not extra, that's total price of the slab as quoted in our price break down. We were originally quoted $3,900 and I actually questioned the $2,000 price increase. It would have to be an additional cost and that would be around about right for an upgrade from M. I can't see it being the total cost for the slab because you'd have to have an allowance for some type of slab in your base price and as part of the standard inclusions. Usually an M as standard. I leave you to fend for yourself, figure things out yourself. Terrence Malick Re: Urgent:what is the general cost of your slab? 12Jun 20, 2009 10:38 am joles GSK Wowo.. We must be getting the bargain of the century for a 41sq house, type HD slab for $5,975? That's not extra, that's total price of the slab as quoted in our price break down. We were originally quoted $3,900 and I actually questioned the $2,000 price increase. It would have to be an additional cost and that would be around about right for an upgrade from M. I can't see it being the total cost for the slab because you'd have to have an allowance for some type of slab in your base price and as part of the standard inclusions. Usually an M as standard. My mistake, you are correct. That price listed is on the extras. Hmmmmmmmm Our house thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=18335 Re: Urgent:what is the general cost of your slab? 13Jun 20, 2009 1:12 pm if you are willing to risk/spend $3 - a site www.diyquotes.com.au gives you a rough estimate, we used it for our 10 m front rendered front fence, gates etc & also used it for a rough price on the new driveway, it was pretty close but that was a few months ago.. good luck Re: Urgent:what is the general cost of your slab? 15Jun 20, 2009 4:28 pm mostly the cost is based around CU mtrs, more concrete = more mesh + more labour... at a slight taper up as the engineering of the slab increases labour and mesh consumption. Where you are coming from is where you are going to... Re: Urgent:what is the general cost of your slab? 16Jun 20, 2009 6:19 pm borg I am building my own house. My slab cost $27K thats for 36 square Borg, where are you located again? Electrical Engineer... Don't hold that against me... And keen owner builder... Mainly the building part!! Re: Urgent:what is the general cost of your slab? 18Jun 22, 2009 8:50 pm We just finished our slab and the total costs of all works on site to date are $28356.91 for 28.5 sq's. M class slab on ground. This includes all site prep, drainage and under slab plumbing, meter box blah blah blah, heres the list from my costs spreadsheet. Site scrape $687.50 Site survey and Set out $660.00 Excavation for footings $693.00 Gravel for temp driveway $174.00 Reo sheet, trench mesh etc $4,832.71 Pump for footings $626.45 Footing inspection $176.00 Concrete for footings $3,003.00 Plumber for sub slab work $4,180.00 Meter Box, SB, CB's, cable etc $415.58 Bricky for pre slab $742.50 Bricks $450.47 Termite treatment (pen's) $264.00 Crusher dust for pre slab $646.00 Excavator for pre slab $544.50 Pump for slab $1,102.00 Concretors $2,280.00 Concrete for slab $6,437.20 Pre slab Inspection $176.00 Misc. $266.00 Re: Urgent:what is the general cost of your slab? 19Jun 22, 2009 9:24 pm So from that I can see you had 29 cu's in the slab and 15 cu's in the footings... heapsa TM and mesh much left over? Where you are coming from is where you are going to... Re: Urgent:what is the general cost of your slab? 20Jun 22, 2009 10:02 pm 18.2m3 in the footings and 41m3 in the slab. Cheap concrete huh Got extra mesh for a tank slab as well, Only had about 3/4 sheet of mesh, a few lengths of N12, 2 lengths of TM and a whole bag of ligatures and a few bar chairs etc left over. I think it might have been a tad over engineered (lots of IB's) but i'm happy to pay a little bit extra to have a stronger slab. You should check your detail drawings, it may show downpipe within brick pier. 14 14099 Render your bathroom walls, two opinions versus the one, makes you wonder. 3 6057 thanks Chippy, i hope they have applied sealer but i am doubt to be honest, so i am gonna do this job after handover. 8 16268 |
