Browse Forums General Discussion 1 Jun 13, 2009 4:56 pm I see so many new houses putting the Solar hot water panels on every conceivable side of the roof, if its not on the north side you will be wasting your time. We installed Solar hot water some years ago and it faces north, yet in winter it still runs out of hot water and thats with 3 panels on the roof. Re: Solar hot water panels. 3Jun 13, 2009 6:51 pm Emzy Doesnt the gas kick in after the solar powered heat runs out? So then you would still have hot water?? Not if you don't have gas. If its connected to mains the booster should kick in if you have not turned it off at the meter. Re: Solar hot water panels. 4Jun 13, 2009 6:56 pm nww1969 If its connected to mains the booster should kick in if you have not turned it off at the meter. Only on night rate. My point is, I have seen so many systems fitted to the wrong side of the roof to be rendered usless, Ive even seen them fitted to the south side of roofs.. Re: Solar hot water panels. 5Jun 13, 2009 6:58 pm Well hope it works anyway. I am planning to inlcude it into the design of a new house: gas boosted solar hot water system. If its worth its while, than I can include it, if not.....gonna have to investigate this!! Re: Solar hot water panels. 6Jun 13, 2009 7:01 pm We've got some condensation in one of our panels on our system. Is this a bad thing? I rang the people we got it off and they said it was ok because we still haven't got the hot and cold taps hooked up properly yet (next week). But my dad and my uncle-in-law reckon its definitely a problem. Is condensation in a panel a bad thing? Sorry to redirect the discussion, just thought it might have been a relevant topic rather than start a new one along the same lines. As for the boost on ours, we're hoping to hook it up to an offpeak 2 tariff and have a switch in the switchboard in the laundry we can turn on to heat some water if we run out of solar. Will be interesting to see how it works once we move in. Cheers, Pete viewtopic.php?f=38&t=8824 the sun master is the solar heating to "warm" the water in the tank the S26 is your hot water system which will heat the water (25 degrees?) so with both turned on you… 2 14049 I want to build a decking to the drawn shape outlined in black. The problem is how close can I build to the gas hot water unit? Will I be able to build around it and be… 0 20230 DIY, Home Maintenance & Repair Hi, I've got a brand new (2nd hand) Bosch Hydropower 16H tankless hot water heater. Since it was installed I have noticed it leaks a lot. I took the cover off and it looks… 0 24147 |
