Browse Forums General Discussion 1 Jun 12, 2009 11:21 am We just got our prelim quote back after getting plans drawn up and they have added in an extra $2000 provisional for storm water connection. Apparently they have to run it down to the back of the block (approx 70m long) rather than run to the front street? Is there anyway I can find out if there is a stormwater provision at the front of our block? I just don't know what to look for. Thanks! Love Kristi Living the dream. 4 horsey acres in the country. What's the next project??? Re: Storm water connection? 3Jun 13, 2009 7:53 pm Guess it depends on the easiest way to run the storm water. We were quoted 6k to run 100m so we took it outta contract and ran it to within 6 metres. Built Liberty 42 - Handover 26th Feb 2010 forum thread: https://forum.homeone.com.au/viewtopic.php?f=31&t=17243 Hello I am developing 2 side by side units. Wish someone can help me on the following questions 1) Which stage should be the storm water pipe installed during the new… 0 7809 If you need to be able to access these then you may need to dig them out and cut them so you can add a socket and a riser to the required height. We normally add a… 1 6842 Thanks for that, the PVC pipe is still about 40cm below ground level and it sticks out of the sand with no end cap or anything on it just open pipe, is this the finished… 2 10466 |
