Browse Forums General Discussion Re: raising ceiling 2Jun 08, 2009 3:15 pm Raffic, i'll answere second question fist- 450mm centres is fine for your walls. If they are only partition walls you can blow out to 60mm centres. As for the ceiling it all depends on the roof framing/truss setup. In most cases you will find that the ceiling is either screwed directly to te bottom chord of the truss or fixed to battens which in turn are fixed to the bottom chord of the truss. Unless yu have a suspended ceiling, i will be a big job raising ceiling heights. If the roof is pitched you will be ableto raise it, however, it is a BIG job, as you wil need to raise all of the ceiling joists. In doing so you may find that the roof line will prevent you from lifting too hight, which means cutting the ceiling joists to follow th roof pitch, and would need to bolt the ceiling joists through to the rafters. As mentioned, big job even for us builders, but yes it can be done. Adrien Mamet How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5947 There is water getting into the ceiling, I expected to find some holes in the corrugated roof but there weren't any so I suspect that the roof drip edge is letting water… 0 2454 It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17202 |
