Browse Forums General Discussion 1 Jun 04, 2009 4:24 pm Hi Guys: I will be doing a simple reno. It will be: - Painting all walls - Pull old carpets over floorboards, then sand and polish - install new kitchen - minor bathroom changes. The question is, what's the best/most logical way of going about these tasks, in what sequence? i.e. paint walls first? or flosh floor first etc? thank you steve Re: Quick Q - Simple Reno Sequence 2Jun 04, 2009 6:17 pm I would follow the sequence you have laid down there. However I would remove the carpet first as the dust you create when you remove it after painting will create more hardwork for you. Try not to get too much paint on the floor when painting(obviously) and follow the sequence you have! Good Luck. Re: Quick Q - Simple Reno Sequence 3Jun 04, 2009 7:31 pm MrFish, I would do the floor first before painting the wall, coz: - If you paint first then take out the carpets, you'll be left with a 10mm high area on the skirt that needs painting. Also, quads will also need painting. - Floor sanding gets dust EVERYWHERE. So, better to do the floor first, then clean the walls and paint. Chris 1. Roof cleaning and paint - which colour do you recommend? I often see black/ dark grey in use these days but I would prefer… 0 8313 Hello It is good to have a planned bathroom reno to suit your budget and design, living for 10 years I think you need a bathtub 4 10355 Bought in Nov 21 at the height of the market (classic). Good area, atrocious floor plan. BUT has land out to the left-hand side that we can extend out on (see second… 0 8766 |
