Browse Forums General Discussion 1 May 01, 2007 10:31 am Hi all,
Just after some opinions on cost to extend a 3 bedroom single brick north facing 60's home.. .adding a master suite (WIR/ Ensuite)...approx 35sqm, a medium size double garage and extending the lounge/family room area by about 35 sqm in two directions. Do you think we could do this for $130-$200k? and should we go upstairs for the master suite to capture local views (of black mountain in Canberra) or out the back on one level? Is there a difference in costs? We also need to renovate the kitchen, bath and laundry...which we have allowed 50-60k including removing one wall and all fixtures staying as is? Is this realistic? Re: Renovating and expanding 3 bm home 2May 01, 2007 10:47 am On 1 level yes, 2 levels no...
35sqm ext will cost approximatley $40K finished (in melb) and just to "go up" is around $100K plus the room plumbing etc. We looked at a master bedroom upstairs and were quoted $125K to $160K. It may be cheaper in Canberra???? Good Luck Matt What you are looking at is fibrous plaster, true gypsum, it is cast on horizontal beds with fibers included to give strength. I has no Asbestos in it. Houses before 1985… 2 7142 We already paid for somfy motors for the blinds. The quote above was purely for “pre-wiring” so the blinds company can install the motors and blinds. That’s why we… 5 16289 Hi, you've probably already resolved this, however, Commbank will probably pay the funds to you after you send evidence the work is done regardless the change in the quotes. 1 35331 |
