Browse Forums General Discussion 1 May 30, 2009 6:56 pm How do you calculate the maximum size house you are allowed to build in Hornsby Shire Council? Since the floor space ratio is 1:0.4, does that include garage, patio, outdoor living areas or are they on top of? Also with the new NSW Housing Code, does their 1:0.5 floor space ratio include garage, outdoor living areas etc?? Still quite confused about the whole thing. eg for a 700 square metres land, what size house would be allowed? Many thanks. Re: Building requirements in Hornsby Council? 2May 30, 2009 9:08 pm I'm not sure, but you may find some helpful info here: http://www.hornsby.nsw.gov.au/planningd ... tionID=228 Judie Re: Building requirements in Hornsby Council? 3Jun 02, 2009 9:57 am I believe the 40% does not include garage, patio and outside living area. So for a 700m2 land you can build 280m2 house plus garage, patio. alfresco etc. You can always talk to the duty town planner at the council. Just give them a call. Re: Building requirements in Hornsby Council? 4Jun 02, 2009 10:27 am Floor space ratio is calculated on the habitable floor. Not including garages patios and entrances. Re: Building requirements in Hornsby Council? 5Jun 02, 2009 3:03 pm Hi Cheeky, I thought this thread was a bit of a deja vu... We've already gone through this on this thread viewtopic.php?f=31&t=13011&hilit=hornsby But if it's still unclear (which is VERY easy) give Hornsby Council a call, the phone queries guy is (at least when we were dealing with him a while back) really nice and helpfull, his number is 9847 6711 if it goes through to voicemail you might want to call the main planning/DA number and ask the receptionist who you can speak to in relation to this... Good luck, it's all very confusing! We got our DA approved in record time (just over 3 weeks) so Hornsby are really getting much faster and maybe more flexible. Building a Wisdom Prosperity 23 - http://erwisdomprosperity.blogspot.com/ Re: Building requirements in Hornsby Council? 6Jun 02, 2009 8:47 pm Thanks, Jericho, for reminding me about the thread. I think I got more confused the more I pondered with this. I think I will have to ring the Hornsby town planner if they are as helpful as PP suggested. Re: Building requirements in Hornsby Council? 7Jun 02, 2009 9:41 pm No probs cheeky, it can get very confusing. Most builders know your maximum size anyway, they can figure it out for you but I would be giving Hornsby a call. Good luck! Building a Wisdom Prosperity 23 - http://erwisdomprosperity.blogspot.com/ Re: Building requirements in Hornsby Council? 8Jun 07, 2009 2:09 pm Hi, I'm new to this site although have been reading the great info for awhile now. I just wanted to put my 2cents worth in regarding Hornsby council requirements. We are also looking at building in the Hornsby area. We were looking at using the new housing code (Complying Development) so that we could have a house that was bigger than the 40% allowed by Hornsby,but because we did not meet the height requirements we now need to use the DA process. The new housing code(Complying Development) is quite strict in that you need to complying with ALL the requirements, not just some. We then found out (from our builder) that if the landscaping is greater that the requirement we would need more water tanks and the list went on. So in the end we are back to the DA. Hornsby will give you 38sq for the garage ie if your garage is 39sq then 1sq will go towards your FSR . They do not count porch alfresco and balcony. The site coverage is the footprint on the land, so the total ground floor including garage, driveway, garden sheds,verandahs etc..and this is also at a max of 40%. Also beware that some land in Hornsby has enviromental restrictions (it is the bushland shire!). The best way to check if your land can have complying development carried out on it (ie build) is to request a Planning Certificate under section 149 from council. It costs about $40.00. Hope this helps someone. Building a modified Allcastle home Re: Building requirements in Hornsby Council? 9Jan 23, 2011 3:00 pm thanks fabricgirl!!! helped me a lot $40.00 well spent. Michael Chan | Australia wide Mortgage Broker Michael@ShapeHomeLoans.com.au | 1300 74 5626 | Fax: 02 8212 8909 http://www.ShapeHomeLoans.com.au This was on google. Development controls 2.3.1 Front setback D1 New buildings within residential areas shall adhere to a front building line, which is 5.5-6m to the… 1 3643 I'm wondering if anyone knows what the requirements are of a builder to be eligible to hold Domestic Building Insurance for proposed works. https://www.dbi.vmia.vic.gov.au… 0 3324 Even if it's not being sub-divided and you want to keep it as Torrens title, you will still need to talk to a town planner or Council themselves, to see if they will allow… 1 11014 |
