Browse Forums General Discussion 1 Apr 29, 2009 11:07 pm Hi All, We took down our old patio structure on the weekend. It was my first go at using my angle grinder. It all went OK, but the following day, I noticed some large windows that were very close to where we were grinding are now slightly pitted. If you run your hand over them, they are all rough and they just look slightly scuffed. This was caused by the constant barrage of sparks from the grinder. Is there some sort of rubbing compound that can be used on the glass that might restore the window (or at least lessen the damage)? Thanks, Chris Re: Can my windows be repaired? 2Apr 29, 2009 11:51 pm hey chris try a windscreen place they have something to get rid of sandblasting on windscreens so maybe stay safe happy building Re: Can my windows be repaired? 3Apr 30, 2009 6:04 am Someone like O'Brien should be able to tell you what your options are. As they do both buildings and vehicles they should know. http://www.obrienglass.com.au/Products- ... 178.0.html Re: Can my windows be repaired? 4May 01, 2009 1:47 pm See if you can get your hands on some Cerium Oxide - make it into a thick paste and use a cloth to rub it onto the glass.. it should get rid of the marks you're talking about. Hubby works for GJ@mes Glass and this is what they use! Re: Can my windows be repaired? 5May 01, 2009 6:04 pm 78xtc See if you can get your hands on some Cerium Oxide - make it into a thick paste and use a cloth to rub it onto the glass.. it should get rid of the marks you're talking about. Hubby works for GJ@mes Glass and this is what they use! Thanks for the tips everyone. Do you happen to know where I could get Cerium Oxide? Re: Can my windows be repaired? 6May 01, 2009 6:53 pm cmooring 78xtc See if you can get your hands on some Cerium Oxide - make it into a thick paste and use a cloth to rub it onto the glass.. it should get rid of the marks you're talking about. Hubby works for GJ@mes Glass and this is what they use! Thanks for the tips everyone. Do you happen to know where I could get Cerium Oxide? Here... http://australianglasstools.com/index.p ... cts_id=338 But if it's really bad have the windows reglazed... Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: Can my windows be repaired? 7May 02, 2009 2:45 pm Thanks all. The damage isn't too noticeable unless you are up close. We are still doing some more work around that area, so once it is all done, I will take a closer look at the windows and see what we can do. Thanks for all the suggestions. Chris Personally, considering your layout (study/work desks in bedrooms), I don't think you have any other option but to leave NW windows and make them as big as possible e.g.… 7 10483 Hi, I'm planning to build a new house and wanted to get some feedback on the different window designs for a master bedroom. Our bedroom is north facing and the bed will… 0 4561 I’m restoring all my 40yr old windows and I want to install seals around the casements. I’ve sanded back and oiled the frames with sikkens. My plan is to box up inside… 0 6521 |
