Browse Forums General Discussion Re: Hallway decorating ... Opinions please 25May 08, 2009 1:15 pm ~*~Moved in on the 16th April 2011~*~ Re: Hallway decorating ... Opinions please 26May 08, 2009 5:57 pm mmm is the picture on the right smaller than the centre and left picture? If so, the the right picture should be swapped with the one in the middle and definitely lose the runner to show off the fabulous table Might cheaper to changer your idea of what makes a home, have you considered building a porch? 2 51794 at most it will have a short lintel which could be moved up just below the ceiling or even above. Above means you need to patch the cornice and might need to deal with… 2 61369 What? It's a lighting question, the control joint is only needed at 12m centres, a bulkhead or change of direction will suffice as a 'break' in the ceiling, just make… 8 8563 |
