Browse Forums General Discussion 1 Apr 09, 2009 12:43 pm Hi Can anyone help with a product used to glue concrete back together? A friend's front yard has concrete posts, one of which has snapped (possibly through vandalism). We now need to glue it back but unsure how this is done. The post is about 30cm by 30cm with a height of about 70cm. Any suggestion would be appreciated. Re: How to glue concrete post back? 2Apr 09, 2009 12:56 pm Would prolly be best to dowel it, but using an epoxy something like one these, if there are some lumps missing http://www.sika.com.au/cmc/Datasheets/t ... 41_tds.pdf or for a clean break http://www.sika.com.au/cmc/Datasheets/t ... 52_tds.pdf will prolly do the job There are heaps of suppliers no need to go with sika, just a guide. onc Where you are coming from is where you are going to... Re: How to glue concrete post back? 3Apr 14, 2009 2:18 pm Might be easier and safer to just replace it alltogeather with a new one. Just a thought. Pat. Sam There is a much stronger glue than liquid nails. It's called T Rex and will stick your timber to the concrete. Cheers Simeon 1 1539 My land is 260m2 (10m x 26m) located in claymore NSW. Under campbelltown council. I know in general the following setbacks would apply ground floor side setback =… 0 6866 |
