For normal batten and pendent, are they actually plug in the same socket?
W are working on electrical plan.....not sure if the socket for pendent is the same as the normal batten one....
Thanks!
Browse Forums General Discussion Re: Normal batten vs Pendent 2Mar 19, 2009 9:20 pm A batten is simply something to put there until you add a feature light at a later stage (unless you like the look of bare bulbs).
You can get different types of light fittings - some are meant as DIY items and just fit over the batten. Lots of oysters and some pendants do this. Others need to be done by an electrician, who'll unscrew the batten to expose the flex and install the new fitting. Have a look at the DIY range at Bunnings to get an idea of what's available. Re: Normal batten vs Pendent 3Mar 19, 2009 9:22 pm as kek said kikin, it is the same socket. just get a batten and your electrician (if you need one) will change it over when installing your pendant. "Your emotions are the slaves to your thoughts, and you are the slave to your emotions." — Elizabeth Gilbert Living in our new house. Currently scaping the land. Yes, get a builder, make sure he is experienced and a registered building practitioner 5 8959 |
