Browse Forums General Discussion 1 Mar 16, 2007 9:34 am We have a 1000 sq m plus block with a 60's house built across the width. We are considering demolishing half the house and building on the back of the retained portion, freeing up land for a subdivision of a block next door. We then intend to build another home on this block. Who do we get to give us information about the viability of the project. In Adelaide, NE suburbs. Re: developing our property 2Mar 16, 2007 10:50 am A 2 lot subdivision requires a planning application which involves meeting local planning requirements plus subdivision requirements [clause 55]
Basically you have to submit an application showing the proposal & how it meets local planning guidlines plus items such as neighbourhood character; overlooking; overshadowing; height limitations; carparking; sewerage; stormwater; landscaping etc - all of which are detailed in 'clause 55'. Initially speak with your local planning dep't & then any competant building designer will be able to prepare the application. Just to clarify - the council will require details on the extension & a full design of the proposed new home on the second block - even though you may not be building it. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. Always handy to have the facts on hand when relying on agents advice, a lot of times sale agents advice is only good anecdotally, and when you actually dive deeper it's… 33 47677 You might be able to apply to divert the sewer at your expense. In NSW you would contact a Water services co-ordinator and they would give you advice as to whether or not… 1 16127 Ask for some kickplate to be added and also for tradies to be requested to use lanyards on tools on that side of the building. Be respectful and have the discussion… 1 1685 |
