Browse Forums General Discussion Re: Pergola Timber advice 2Mar 15, 2007 6:52 am Other than using a steel column such as 90*90 square hollow section it is not easy to find a timber that won't crack or splinter to some degree.
Even within species there can be variation in quality. There is a requirement to use 'durability class 1 or 2 timber or H3 treated timber for exposed to the weather structural members. In some cooler drier climates the use of other timbers with the correct application of protective coatings & regular maintenance may suffice but this is subjective. In Vic I would recommend H3 treated pine with a stress grade rating of F7 or if available F8. Select posts free of sap lines & either use a good exterior primer with 2 coats of exterior top coat or a liberal coating of good pentrating stain. At the end of the day regular maintenance is the key. Peter Clarkson - AusDesign Australia www.ausdesign.com.au This information is intended to provide general information only. It does not purport to be a comprehensive advice. i think option 2 is much better with easy access to the garden without having to walk through the new sunroom which makes it a better room for guests and TV .a simple… 2 8229 Is there a building permit? RU in Victoria? What is the value of the building contract? 1 6831 About a year ago, I embarked on a DIY project to construct an outdoor Pergola, which measures approximately 5.2 meters by 4.0… 0 29608 |
