Browse Forums General Discussion 1 Mar 16, 2009 10:17 am Just noticed this week, there are some cracks on my garage concrete. They are across the whole garage in a line. The crack gap is small, less than 1mm. I asked PD maintenance team. They said it's normal as the house settels?! I really doubt it, as this may indicate the slab is actually starting to crack as well. Not sure how they are going to fix it. Any suggestions will be appreciated.
Thanks, Re: Garage Floor(slab) cracks - serious? 3Mar 16, 2009 10:41 am It does not sound like anything to worry about.we have a brand new house only been it in 9 months there are cracks all over the place had them looked at and was told they were fine only worry if they start to open up and as the past post said and you can fit a key in finished building 40 square home on 5 acres with perry homes.working on the landscaping just finished pool deck with ://forum.homeone.com.au/viewtopic.php?f=31&t=2217 Re: Garage Floor(slab) cracks - serious? 4Mar 17, 2009 8:19 pm tomking.chen Just noticed this week, there are some cracks on my garage concrete. They are across the whole garage in a line. The crack gap is small, less than 1mm. I asked PD maintenance team. They said it's normal as the house settels?! I really doubt it, as this may indicate the slab is actually starting to crack as well. Not sure how they are going to fix it. Any suggestions will be appreciated. Thanks, NORMAL?!? How did PD explain to you about that crack? Did PD tell you why it's happened? By the way, which floor plan did you build in PD? Metricon Amira Re: Garage Floor(slab) cracks - serious? 5Mar 17, 2009 8:35 pm It is fine!
We have several hairline cracks in our slab too. Re: Garage Floor(slab) cracks - serious? 7Mar 18, 2009 3:21 pm We have cracks in the slab as well, and have planned large format tiles. The much wiser brother advised to ask for spare tiles to be supplied in case of future cracking and to ensure tile consistancy. Not a garage issue I know, but may be helpful to others. Re: Garage Floor(slab) cracks - serious? 8Mar 19, 2009 6:23 pm As everyone else has mentioned, it's fine! As long as you can't get a key/dollar coin in it there is no structural issues.
It can occur for many reasons! I've got cracks in mine because it started spitting when they did the slab. Might also occur if it was a really hot day when they poured or was curing It sounds like you have a crack in your garage where the wall meets the ceiling, along the shadow line on the… 0 17201 The CSIRO BTF18 explains differnt types of cracks and what "normal" is Google this and the top result is actually the latest version. You normally have to buy this from… 9 9320 isn't a garage level with the rest of the house a given? pretty sure they 'came around' long time ago. if you have a flat block, the garage is usually level with the rest… 1 17526 |
