Browse Forums General Discussion 1 Mar 06, 2009 1:39 pm Has anyone here achieved a 5 star energy rating?
As part of the new energy efficiency scheme all new houses approved (in QLD) after 1st march must comply with the 5 star requirements. I am about to submit to council and need to know what sort of insulation i will be putting in walls and ceiling but because the 5 star has just become a requirement there is very little info around. Re: 5 star energy rated homes 2Mar 06, 2009 1:56 pm All new houses built in Victoria need to have a 5 star energy rating 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: 5 star energy rated homes 3Mar 06, 2009 2:01 pm 5 star depends on allot of things, like window facings and such.
Minimum insulation is 3.5 in the roof and 1.5 in the walls IIRC Re: 5 star energy rated homes 4Mar 06, 2009 2:06 pm OK, so do you know what your builders have done to achieve that 5 star rating?
What sort of insulation in the roof? did you need insulation in the walls. if so what sort? what colour is your roof? have you got heating / air conditioning? Re: 5 star energy rated homes 5Mar 06, 2009 2:08 pm Hellman109 5 star depends on allot of things, like window facings and such. Minimum insulation is 3.5 in the roof and 1.5 in the walls IIRC OK, now we are getting somewhere? I realise that a lot of it is to do with orientation but i cant change that now as i have just applied for siting relaxatation to council. But i can still change what we intend to use for insulation etc. Re: 5 star energy rated homes 6Mar 06, 2009 2:13 pm Hellman109 5 star depends on allot of things, like window facings and such. Minimum insulation is 3.5 in the roof and 1.5 in the walls IIRC I think that insulation bit depends on where you are and also, like you said, everything else - I don't think my builder does that insulation as standard 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: 5 star energy rated homes 7Mar 06, 2009 2:14 pm wake_me OK, so do you know what your builders have done to achieve that 5 star rating? What sort of insulation in the roof? did you need insulation in the walls. if so what sort? what colour is your roof? have you got heating / air conditioning? In Vic, they need to include either a solar hot water system or a rain water tank - then I think the rest depends on orientation etc but I'm really not sure - the builders will put in as little as possible 'A bottle of wine contains more philosophy than all the books in the world.' Louis Pasteur Vegie garden: viewtopic.php?f=19&t=27637&start=0 My Backyard Adventure Re: 5 star energy rated homes 8Mar 06, 2009 2:15 pm http://www.yourhome.gov.au/technical/fs47.html
i think this site can provide you some good information Blog - http://clageonewhouse.blogspot.com/ Building Thread - viewtopic.php?f=31&t=10886&hilit=milan I am in, with my husband and my beautiful bunny Re: 5 star energy rated homes 9Mar 06, 2009 4:58 pm Every house is different. Climate is a factor, plus orientation, size of house, and things like number and size of windows, ventilation - all sorts of things.
There's no set formula and it probably varies from state to state. Our house achieved a 5-star rating just "as-is", we didn't have to change a thing from the builder's standard plan. One thing to check: find out whether your builder includes the 5-star rating in the base price, or if you have to pay extra for any upgrades to achieve it. Re: 5 star energy rated homes 10Mar 06, 2009 5:25 pm Thanks kek,
I have designed our house my self and my father in law will be building it so no base price or inclusions, just what ever it costs. Dont know if thats good or bad sometimes as every time we look around we upgrade something. I just popped down to the local insulation shop and they have given me a good indication of what i need insulation wise. Its pretty much what i was thinking; R 4.6 silver batts on ceiling joists with sarking under colourbond concertina foil and sarking in the walls which will give me r2.2 They also recommended to vent the eaves and install a few whirly birds, also install some registers / vents above clothes drier and fridge. Re: 5 star energy rated homes 11Mar 06, 2009 6:44 pm ^^ Seems a bit overkill.
On a builders plan were going to build we have... 4.0 bats in the roof 2.0 bats in the walls exhaust fans in bathrooms (not toilets) draft stoppers under doors as requires Solar + gas boost hot water Thats about it IIRC, oh and water efficient taps/shower head. Re: 5 star energy rated homes 13Mar 06, 2009 7:27 pm Run your plans past AUSDESIGN.com.au or someone locally in QLD
http://www.ausdesign.com.au You need a bit of software to do the required calculations. Re: 5 star energy rated homes 14Mar 08, 2009 8:50 pm Hellman109 ^^ Seems a bit overkill. On a builders plan were going to build we have... 4.0 bats in the roof 2.0 bats in the walls exhaust fans in bathrooms (not toilets) draft stoppers under doors as requires Solar + gas boost hot water Thats about it IIRC, oh and water efficient taps/shower head. Not a lot of difference between your insulation r values and mine. Why do you think thats overkill? What state are you in Hellman? From what you've described I can assume your not in qld. Re: 5 star energy rated homes 15Mar 08, 2009 9:58 pm My certifier has informed me that as the plans were past a certain point when the new 5 star rating became effective i can have the house approved under the old 3.5 star system if i like.
The question now is do i run with that as its going to be cheaper now, or do i aim for the 5 star and hope that the extra costs will be recouped in savings on energy bills over the next few years and / or in re sale? I'd guess i'd be looking at at least $1500 - $2000 extra material costs to meet 5 star and obviously these extra costs are going to take quite a while to re coup in savings on energy bills, so if i sell within a few years is it going to increase resale? Is someone going to buy one house over another or pay more because its 5 star, probably not. I personally would put more emphasis on practical design and location, in which case a high energy efficiency rating is simply a non value adding sweetener. So my dilemma now ****** in which way to go I'm thinking that i might just pay someone to design what is required to meet the 2 assessment levels and then get quotes based on each option. Otherwise i'm gonna do a head gasket Re: 5 star energy rated homes 16Mar 08, 2009 10:33 pm If you are investing in comfort for your family and disregard investment - then go 10 star - or whatever you can afford on the road to 10 star.
If you are likely to move in the short term - forget the 5 star rating and take what you have, just build and cop the energy cost in the short term. The government's idea of 5 star efficiency is so low it is irrelevant. Ed "ECOECO" At 'EcoEco', we design windows, we design the best windows, we do it for you, so that when you’re happy we are happy. Tel. 1800 326 326 Re: 5 star energy rated homes 17Mar 10, 2009 9:18 pm Thanks Ed. I opted to pay someone to do an energy efficiency design so i can get accurate quotes and make an informed decision rather than a guess (in regards to the initial cost differences atleast.) Re: 5 star energy rated homes 18Mar 11, 2009 12:05 am ed @ EcoClassic If you are investing in comfort for your family and disregard investment - then go 10 star - or whatever you can afford on the road to 10 star. If you are likely to move in the short term - forget the 5 star rating and take what you have, just build and cop the energy cost in the short term. The government's idea of 5 star efficiency is so low it is irrelevant. Ed What's required of a 10 star energy rating?? I never knew such a rating existed. (Sorry for Hijacking your thread wake_me) Re: 5 star energy rated homes 20Mar 15, 2009 8:51 pm ed @ EcoClassic The government's idea of 5 star efficiency is so low it is irrelevant. Ed Well, having scanned through this whole 5 star thread thinking what a complete joke that rating is, its nice to find I am not the only one with the same view. 5 star - what a joke! 10 years ago was a different software than we use now. it has had a lot of changes over the past years. Improvments to the software and changes to how Nathers models need… 8 1570 go upvc window frames ensure insulation under colorbond. not just sarking, lighter color roof also not sure if you have seen this viewtopic.php?t=5823 last couple of pages… 4 110853 Ask for references and speak to them. If they are defensive or try to avoid the request, walk. 1 75929 |
