Browse Forums General Discussion Re: things to look when buying a land & building a house 2Mar 03, 2009 8:57 am builders are keen tohaggle now to get the business so make sure you get something extra. if they have a special options package, say you will go ahead if you also get x, y or z.
the mooe level your land and the wider the frontage the chepaer it will be to build. the steeper you get the more interesting designs and feel you will get but the cost will rise. also remember that the standard project builders will not modify their designs unless you pay lost more money. Re: things to look when buying a land & building a house 4Mar 04, 2009 9:45 pm If l ever had to buy land again, l would not commit to it until l got an independant and thorough soil test ...the site costs can be a horrendous and a nasty shock if you've bought a block and committed to yourself to a builder.
Know what your patch of dirt is comprised of and research the costs involved for slab design/footings etc. We thought we bought a pretty normal block...turns out it was far from it. Although our site costs were much higher than we and the builders expected (that's another story)....compared to some others here, we were very fortunate indeed that it wasn't double or triple the amount. Also as maya said...research as to what infrastructure is planned for around your area. Re: things to look when buying a land & building a house 5Mar 05, 2009 5:21 am I looked at traffic flow, if parking for nearby school would be a problem and the big one for me, headlights in the front windows. As I wanted a big block, the standard 450 sqm blocks were the middle section of the road and the larger ones off to the side near corners. cars turning will always shine headlights into the front room and in my case the home theatre. Licenced Sparky and Data Cabler If "The Data Guys" is too long to type, TDG will do. Re: things to look when buying a land & building a house 6Mar 05, 2009 7:57 am The Data Guys and in my case the home theatre. You can always have blackout curtains. Ill be down in a circut (U shape off a main road, so only very local traffic) but Im putting them in to make it work better. Re: things to look when buying a land & building a house 7Mar 12, 2009 7:03 pm some very useful information there finished building 40 square home on 5 acres with perry homes.working on the landscaping just finished pool deck with ://forum.homeone.com.au/viewtopic.php?f=31&t=2217 Yeah I don't know why I came to a forum. Place is full of wierdos/pedos thought internet may help but I suppose I'll try my luck with someone in person. Cheers. I tried… 0 6448 Depends what you're current inclusions are, but we're not including wardrobes and will just use second hand ones until we can save later on to get them built. Also have a… 3 11648 No the fireplace doesn’t work. It’s been enclosed. I’m not sure what was removed, as it was done quite some time ago - well before what I can see with photos online… 2 11589 |
