Browse Forums General Discussion 1 Feb 23, 2009 2:57 pm Hey guys, we are undecided on which way to go with our ceilings. House will be approx 31 squares and is a double storey construction, which do you think would be the better option ?
A) Ground floor 2590 & first floor 2590 B) Ground floor 2700 & first floor 2400 (cost is similar to option A) c) Ground floor 2590 & first floor 2400 & save $2000 for other upgrades ? First floor will have evap cooling regardless of ceiling height. Thoughts ?? Re: ceiling heights 2Feb 23, 2009 3:36 pm We're going for option C in our house. 2400 is standard and we're upgrading to 2590 downstairs.
IMO only the ground level really needs the extra head space for an open feeling. The standard ceilings upstairs gives a nice contrast. Not sure if you have to start thinking about taller doors with the 2700 ceilings or whether it's anything above that Stevep79 & Principessa Finished building Wisdom Homes Impression 33mkII in The Ponds, Sydney http://lilypadintheponds.blogspot.com Re: ceiling heights 3Feb 23, 2009 7:03 pm Go with the high 9ft 2700mm ceilings in downstairs. Leave upstairs as is at 2400mm. Downstairs as Steve mentioned you could upgrade to large internal doors. Built 36sq Plantation "Retreat" on 4460m2 at Spring Mountain, Qld In Living and landscaping.. >>> ... http://retreatspring.blogspot.com Re: ceiling heights 5Feb 23, 2009 7:36 pm Standard height doors (2040mm) are still normally used with 2700mm high ceilings. Older houses with 3000mm or 3600mm high ceilings often incorporated a glass window above the door to allow light etc.
Its fairly common these days for entry doors to be higher than a standard door (2340mm I think) Re: ceiling heights 6Feb 23, 2009 8:21 pm I'd go B - higher ceilings give an element of spaciousness and luxury. Building Upside down house in Wantirna VIC Current Stage: Procrastination... it's just all too hard.... Blog: http://thereluctantbuilder.blogspot.com/ Re: ceiling heights 9Feb 25, 2009 12:05 pm I will go for (D) if budget is not an issue
(D) both ground floor and first floor 2700mmm Otherwise (B)... Re: ceiling heights 11Feb 26, 2009 9:38 pm Option A, because your house would be much cooler on ground and first floor.
I did 2750mm on both floor and when it was 40+ degree, the house was still reasonably cool without using any cooling. I did extended all my doors to that height to match too, so it doesn't look weird. Sh*tmonds new slogan of "We in it together" is so perfect fit, because you be "In the sh*t together" once you signed with them. Villa Grande 5600 Re: ceiling heights 13Feb 27, 2009 9:19 am ken007, apparently Sh*tmonds are getting their act together, so you got two choice, you can either take your deposit back or make sure you keep you eye on your progress like a eagle and prepare for some really hard yard and no communications from them.
Also make sure you have an independent inspector to check at different stages of your house. I know lots of people here do. I've got friends and neighbors ask me why i use an independent inspector, because they didn't use one and the house they build seems fine. Its like "What you don't know, then it won't hurt you" but as years gone by, it sure will, unlike any other things you buy, you are paying for it from 10-30yrs and you might live in it from 5yrs to rest of your life. Having later on down the track to find out your house isn't up to the Australia standard because the defects are slowly affecting the structure of the whole house would be way too late. Good news is, the ******* supervisors that was working on my house are no longer with Sh*tmonds. But the 2 face regional manager still is. Where are your building ken007? Sh*tmonds new slogan of "We in it together" is so perfect fit, because you be "In the sh*t together" once you signed with them. Villa Grande 5600 Re: ceiling heights 15Feb 27, 2009 10:02 am Oh north side, well most of the Sh*tmonds problem are in Westside, so you kind of safe (for now). I'm building in Point Cook, which is of course westside.
Castle? nah, i just want my future kids to have lots of space to run free. Sh*tmonds new slogan of "We in it together" is so perfect fit, because you be "In the sh*t together" once you signed with them. Villa Grande 5600 Re: ceiling heights 17Feb 27, 2009 1:38 pm klo338 Castle? nah, i just want my future kids to have lots of space to run free. Inside or outside the house? Cause you wouldn't have much land left after that? OT: We've got 2590 lower and 2400 upper and it seems ok...the void must help somewhat. Re: ceiling heights 18Feb 27, 2009 2:13 pm ken007 Our developer has got a release down that way also, think its called Williams Landing ? Yeah i had a look at Williams Landing and their plan, the proposed shopping centre is huge. Got a friend who just bought a land there. We bought our land 2yrs, so that was before Williams Landing released. joeygbh Inside or outside the house? Cause you wouldn't have much land left after that? OT: We've got 2590 lower and 2400 upper and it seems ok...the void must help somewhat. lol well inside, for outside, we are facing a park, plenty of room there for them to run free. Sh*tmonds new slogan of "We in it together" is so perfect fit, because you be "In the sh*t together" once you signed with them. Villa Grande 5600 Building Standards; Getting It Right! We bought a house in 2015 advertised as a 7/2/2, 4br up, 3br down (7br), and to date, it’s a great house. However, we’ve just had it valued and it’s come in as a… 0 11988 How do you remove one of these ceiling air con vents? And is it possible to disconnect the duct joined to the vent from inside the house, without going into the roof cavity? 0 5947 There is water getting into the ceiling, I expected to find some holes in the corrugated roof but there weren't any so I suspect that the roof drip edge is letting water… 0 2453 |
